Help finding part
Help finding part
Home › Forums › General Questions › Help finding part
  • #268075
    Andy Sproule
      @andysproule22368
      By any chance could someone tell me where I can buy handles like these have searched the net with no luck?Approx eight inches long by 2 inch diam.20150420-13-8.jpg
      #24894
      Andy Sproule
        @andysproule22368
        #268079
        Mike Poole
          @mikepoole82104
          Go on, give us a clue what it's for, I don't immediately recognise it.
          #268081
          Trevorh
            @trevorh
            Looks like a plug and socket for the cables
            trevor
            #268090
            Speedy Builder5
              @speedybuilder5
              handles for an Electric Chair ?
              #268092
              Bazyle
                @bazyle
                Bicycle spares? it does look like it was a plug of some kind repurposed.
                #268407
                Andy Sproule
                  @andysproule22368
                  Its the handle of a device that is used to treat honeybees by vaporizing oxalic acid.May be made up specially have been searching for something similar but no luck.
                  #268510
                  Tim Stevens
                    @timstevens64731
                    It looks to me like a device made in very small numbers*, out of Delrin rod or similar, so it should be fairly easy to make something similar (or even very similar if you need interchangeability). Or it could be anodised aluminium, and apart from the anodising just as easy to copy. If only we knew what went on inside it. It can't be just a handle, or the wire/pipe going in one end would come out the same colour …
                    * I expect that the demand for oxalic acid vaporisers is fairly small, after all.
                    Regards, Tim
                    #268513
                    Richard Marks
                      @richardmarks80868
                      Get in touch with Clive Hartland, he should be able to help.
                      #268536
                      Andy Sproule
                        @andysproule22368
                        Thanks for replies.Tim its a handle come housing to hold the device the black cable is 240v in, the orange 240 volt outThe device is mounted on a metal frame which then goes down inside the plastic handle.I thought the plastic may have come in two parts so I could bolt it on to the frame.Will make it out of delrin I think.
                        #268554
                        Clive Hartland
                          @clivehartland94829
                          I have never used an Oxalic acid vaporizer, I see them advertised quite often. I do trickle treat Oxalic liquid into the gaps of the combs, but this means stripping a hive down to the brood chamber. I now use a soft pad type Varroa treatment which the bees immediately break into small pieces and tip out of the front door! They seem to do quite well and my Varroa drop is quite small. The Varroa are sometimes picked up by bees from visiting plants and flowers that are visited by bees from other Apiaries. The nearest to me must be about 3 to 4 miles away. It is wild bees that can be a problem so i make sure I collect all swarms and house them and treat them.
                          #268557
                          Andy Sproule
                            @andysproule22368
                            Hi Clive,this is the Sublimox type 30 seconds per box you don't have to open hive and no harm to Queen or workers.Sorry for talking about beekeeping on an engineering forum.
                            #268562
                            not done it yet
                              @notdoneityet
                              Try Icko. They market the things, so they should be able to supply parts. I sublimate from below with my home made varrox type.
                              Alternatively, being as you already know what it is, why not try the beekeepingforumdotcodotuk? Hivemaker will know, I daresay.
                              #268666
                              mark costello 1
                                @markcostello1
                                Bees are interesting too.
