Harrison Milling Machine
Home › Forums › General Questions › Harrison Milling Machine
  • #271967
    mark jewell
      @markjewell80796
      Hi Guys .. I'm new on here but after looking through old posts it looks to be a great site. I have just bought a Harrison Milling machine that comes with horizontal & knuckle head but hasn't got the 'brake arm' on the side. It came from a school about 12 years ago and has never been powered up since. The school had painted it Black and looks messy so I'm going to strip the machine and give it a new coat of Harrison blue/grey paint. Do any of you guys on here have any manuals for a machine like this ? also the power feed gears fitted are 43/38 … any ideas where I can get the rest to complete the full set ? Regards Mark
      #24938
      mark jewell
        @markjewell80796
        #272068
        Phil Whitley
          @philwhitley94135
          Hi Mark, I also have a Harrison H mill with the Harrison vertical head. You can get lots of info, and the manual from http://www.lathes.co.uk . There is also a couple of milling machine books available, one which used to be a companion to the Harrison Mill, the title escapes me but I am sure someone will come up with it, possibly before I remember!
          Phil
          #272143
          mark jewell
            @markjewell80796
            Hi Phil , thanks for your help please let me know the name of that book if you remember.. would be interested in getting that regards mark
            #272263
            John Stevenson 1
              @johnstevenson1
              The gears can be modified from Myford ones by pressing in a keyed Bush. As long as the two gears total 82 you can use any ratio and not be limited with what Harrison’s supplied.
              #272387
              Phil Whitley
                @philwhitley94135
                searching my computer for it N#Mark, I think I have a pdf of it!
                #272392
                Phil Whitley
                  @philwhitley94135
                  milling machine practice by H C Town, can't find a pdf of it, but you can get it from Tee publishing!
                  #272393
                  Phil Whitley
                    @philwhitley94135
                    Vertical milling in the home workshop, by Arnold Throp is also very good, and written by a man who started his apprenticeship at Cole,Marchant and Morley, in Bradford, building steam engines!
                    #272454
                    mark jewell
                      @markjewell80796
                      Thanks Phil & John .. your info is much appreciated..I will be stripping the Miller over the Xmas break and giving it a full overhaul and paint along with looking for Star Points in the motor so I can run it on my rotary converter.. I'm sure I'll be back asking for more of your knowledge.. thanks guys
