Would you not be better off using a horizontal rotary table on a shaper.
This gives you loads more control over the process, especially once you get to depth.
I’ve found making vertical slots up to 12mm in aluminium a doddle on a converted hand shaper.
A shaper has zero vibration, I believe that vibration is a serious handicap when things get to the sort of depths you are suggesting.
The vibration energy is being transferred into sound, which is why the process is making such a racket.
A shaper is almost silent because it’s only cutting metal and the energy transference is only creating heat.
Edited By ady on 10/11/2011 01:30:21
