Gear drive problem
Gear drive problem
Home Forums General Questions Gear drive problem
Viewing 25 posts - 1 through 25 (of 29 total)
  • #299643
    Jim C
      @jimc
      I have been asked to post this question which is from a sample of questions relating to the topic of Mechanical Principles:
      A compound gear train has input Gear A having 10 teeth, which drives Gear B having 36 teeth. Gears B and C are on the same shaft and Gear C drives Gear D, which has 40 teeth. Given the Velocity Ratio of the gear train is 1:12, determine the number of teeth on Gear C.
      We can get the number of teeth on gear C but are confused about the ratio as written.
      Thanks in anticipation of your thoughts. Jim.
      Jim C
        @jimc
        #299645
          1:12 Looks a fairly standard way to express a ratio to me.
          What answer did you come up with for your Homework? Its a bloody big gear!
          Edited By JasonB on 26/05/2017 08:15:10
          #299647
          Martin Connelly
            @martinconnelly55370
            I think it is 12 teeth. The question regarding the ratio is should it be 1:12 or 12:1? If it is for a threading solution for a lathe gear train then 1:12 may make sense. If direct drive gave a tpi of 1 then the calculated gear train would give a tpi of 12. If you are looking at the ratio of input rpm to output rpm then 12:1 would be the correct ratio.
            Martin C
            #299649
              Yes for the given ratio of 1:12 you would need 1440T but for a reduction ratio of 12:1 you would only need 112T
              1:12
              10/36 = 0.277777
              x/40   = 43.2
              43.2 x 0.27777 = 12
              So 40x 43.2 = 1728T
              12:1
              10/36 = 0.27777
              x/40 = 0.3
              0.3 x 0.27777 = .083333
              So 40x 0.3 = 12T
              Edited to correct 36T not 30Tblush
              Edited By JasonB on 26/05/2017 10:11:46
              #299651
              Jim C
                @jimc
                Hi Jason and Martin.
                Thanks for having a go at this. We do indeed get 12 teeth but only if we use a ratio of 12:1. But as Jason said, if we use the examiners ratio of 1:12 it is a massive number of teeth !!!!!
                As I understand things, the ratio of 1:12 would indicate and input of 1 and an output of 12??
                Thanks chaps.
                #299657
                Martin Connelly
                  I would tend to discount the massive gear solution as it does not seem logical to have a first stage that reduces the rpm followed by such a massive increase in rpm at the second stage. However maybe this silly solution was what was required to test if the person being tested really understood the calculation process for the gears.
                  Martin C
                  #299658
                    Posted by Jim C on 26/05/2017 08:27:11:
                    Conventional wisdom is here: **LINK**
                    http://www.the-warren.org/quiz/gearratios.htm
                    … and many other places.
                      Not in my book. ':' means divide so 1:12 is one twelfth. For example,
                      • A 12:1 mix of Acid and Water means 12 parts of acid to 1 part of water. ( 12 times more acid than water, 12 acid divided by 1 water )
                      • A 1:12 mix of Acid to Water means 1 part of acid to 12 parts of water. ( 12 times more water than acid, 1 acid divided by 12 water)
                      Gear ratios confuse me because there are always two ways of looking at them depending on what you're thinking of, a change in speed or a change in torque. The velocity ratio is the opposite of the torque ratio, so a 1/12 velocity reduction is a 12 x 1 torque increase and vice versa. While I have no problem visualising this for gear pairs it's amazing how bewildered I get calculating compounds.
                      Edit Michael_G thinks and types faster than me…
                      Edited By SillyOldDuffer on 26/05/2017 09:52:49
                      #299665
                      not done it yet
                        @notdoneityet
                        Perhaps it was just a question to sort out those that apply the definition correctly? Or possib
                        y an error on the question writer's part. I prefer to use term for gear trains as speed 'reduction' or 'multiplier' – no ambiguity possible then.
                        I once had a degree level question that asked for the output of a one megawatt turbine if the rotor diameter was doubled. I answered ''One megawatt. Attempting to increase the output of a one megawatt turbine by a factor of four (by quadrupling the swept area) would 'let the smoke out' – ie the turbine would fail." A bit like noon and midnight – they cannot be 12am and 12pm by definition! Midnight is actually both 12am and 12pm! Noon is the meridian.
                        #299679
                        duncan webster 1
                          @duncanwebster1
                          Is this yet another ambiguous question from a British GCSE? When my kids were going through this I kept on finding ambiguous or unanswerable questions, for instance find the solution to an equation which had 2 unknowns, there are an infinite number of solutions. Worst of it was the maths teacher wouldn't accept there was an issue.
                          However in this case both
                          and
                          agree that a 1:12 drive is speed increasing. Only an idiot would design such a train with the first 2 as quoted, so I reckon the question setter has got it wrong
                          #299680
                          Bill Davies 2
                            @billdavies2
                            Taking Duncan's first link, the results will be consistent, if unlike the method taught to me as a young engineer, as mentioned above: driver over driven (times driver over driver … – I know the example shown is pulleys).
                            Driver over driven is 40/120 = 1/3 0r 0.333…
                            RPM of output = RPM of input * 1/3 = 100 * 1/3 = 33.33… RPM
                            It looks to me like the level of course is using division, as again multiplication of the input by the ratio, as I was taught.
                            Bill
                            #299681
                              Just an aside, Duncan …
                              Do you agree that the BBC BiteSize "definition" [in your second link] is itself rather counter-productive ?
                              [quote]
                              Velocity ratio = diameter of the driven pulley ÷ diameter of the driver pulley
                              [/quote]
                              … I wonder if they actually understand the word 'ratio'
                                Posted by not done it yet on 26/05/2017 10:41:48:
                                You do have to watch out for what examiners are after. My career included a spell in Systems Analysis which is about understanding business processes so that they can be computerised. Back then we were taught that most business units don't properly understand the detail of their own processes and that embarrassed staff and managers will make answers up rather than admit they don't know what they're talking about.
                                As flushing out the truth was an important part of systems analysis, it wasn't unknown for exam questions to contain deliberate ambiguities and mistakes that you were meant to identify and explain how you would deal with in the real world. In comparison, provided you could do the maths, the numeric questions were a doddle because they were logical.
                                So when you answered the turbine question:
                                • the 'it will make smoke answer' got full points, or
                                • you got told off for failing to calculate a theoretical answer and explain what was needed to uprate the turbine, or
                                • you got credit for spotting a badly worded question and they fixed it, or
                                • you were punished for not understanding what they meant!
                                • no-one made any comment one way or the other.
                                I've no idea what the right answer would be. I hate exams!
                                Edited By SillyOldDuffer on 26/05/2017 13:46:22
                                #299691
                                not done it yet
                                  @notdoneityet
                                  I got a distinction rating for that paper, so I reckon my result and reasoning/explanation was more than adequate. Most, I believe, answered 4MW and were probably marked as correct. The problem arose, I think due to the first part of the question being about a described turbine and the later part using the definite article rather than the indefinite article. It was a low mark question anyway. At least it was not a 'multiple guess' question like a lot of the GCSE papers these days!
                                  #299699
                                  Tim Stevens
                                    @timstevens64731
                                    The ratio of 12:1 gives quite different 'answers' depending on whether you are measuring speed (rpm, etc) or torque as the input and output. One goes up as the other goes down. So, as written, the term 'velocity ratio' is quite helpful (even if it is rpm that we are measuring, not speed in a given direction as such. Get back into pedant's corner).
                                    Those with an eye for precision will tend to put the numbers round the logical way; those with an eye for neatness will generally start with 1:
                                    As an ex-examiner, I would try to give most marks to an answer which recognised the duplicity involved, and took account of it.
                                    Cheers, Tim
                                    #299719
                                      Posted by Tim Stevens on 26/05/2017 16:19:10:
                                      … So, as written, the term 'velocity ratio' is quite helpful (even if it is rpm that we are measuring, not speed in a given direction as such. Get back into pedant's corner).
                                      It may ease the pain, Tim, if you assume 'angular velocity ratio'.
                                      duncan webster 1
                                        @duncanwebster1
                                        Just to be a bit thick, if you double the size of the disc, but reduce the speed to half, the blade speed stays the same and so the blade root stress is reduced (mass * velocity squared / radius). However you have double the blade area to pass steam through, so why can't you double the steam flow and hence power output. It wouldn't be terribly convenient as you'd be generating 25 hz. All UK electricity generating staem turbines run at 3000 rpm, and have 2 pole generators. This probably limits disc diameter via root stress.
                                        #299772
                                        Perko7
                                          @perko7
                                          What i learnt in engineering classes too many years ago was that if there was any ambiguity in the question then your answer should always be preceded by a statement giving your understanding of the question. That way you could never be wrong as you were always answering what you thought the question was asking, even if this was different from what the examiner intended.
                                          That being said, my understanding of the conventional expression of gear ratios is the ratio of the input speed to the output speed, as is the norm for automotive gearboxes and differentials, but unfortunately most of my engineering textbooks from the 70's seem to be inconsistent in this matter. Some of the worked examples confuse the issue by giving a gear ratio of 3:1 and then stating the driving gear is to be the smaller of the gears.
                                          #299782
                                          Martin Connelly
                                            Duncan, the reported question does not mention either steam or turbine disks, the use of the work rotor makes me think of a car's turbocharger turbine. The turbine disks on a gas turbine may be spinning in the region of 15000 rpm at a lot higher temperature than a steam turbine. Doubling the disk diameter would probably result in a design that could not take the stresses unless the rpm is reduced. What seems like a simple question on a test paper could have a complex answer. I think people who had done the course would know what the expected answer would be based on coursework covered.
                                            Martin C
                                            #299797
                                            duncan webster 1
                                              @duncanwebster1
                                              Posted by Martin Connelly on 27/05/2017 08:20:21:
                                              Martin C
                                              I doubt you've got a one megawatt turbocharger on your car. Same argument applies if it's a gas turbine, double the diameter, halve the rotor speed, double the gas area, double the power.
                                              #299799
                                                No doubt the question was set by the engineer brother of the literature professor who set the Shakespeare paper…
                                                http://www.theguardian.com/education/2017/may/26/error-gcse-paper-leads-to-apology-ocr-exam-board-romeo-and-juliet-tybalt-shakespeare
                                                #299802
                                                duncan webster 1
                                                  @duncanwebster1
                                                  Posted by Neil Wyatt on 27/05/2017 10:45:02:
                                                  I love the way a spokesperson blames a typo. Getting one or 2 letters wrong is a typo, writing Capulet when you meant Montague is a cock up, which should have been spotted in the checking process, or don't we bother with those any more.
                                                  #299804
                                                    Posted by duncan webster on 27/05/2017 10:55:55:
                                                    An interesting interpretation of the spokesperson's statement, Duncan
                                                    … I read it rather differently:
                                                    [quote, with my added emphasis]
                                                    Typos are easy to make, but a mistake of this sort is rather unforgivable
                                                    [/quote]
                                                    Hopper
                                                      @hopper
                                                      Oh oh. Stones, glass houses, pots, kettles, black etc etc.
                                                      It was not the spokesperson who called it a typo. The spokesperson quite correctly called it an error. In fact nobody called it a typo. A language teacher, speaking out against the exam board, said "Typos are easy to make, but a mistake of this sort is rather unforgivable" implying it is a different sort of mistake from a typo.
                                                      See how easily these things can happen? And, no we don't bother with the checking process any more. wink
