Gas tank – S/S or brass?
Home › Forums › Materials › Gas tank – S/S or brass?
  • #29634
    Rik Shaw
      @rikshaw
      #257496
      Rik Shaw
        @rikshaw
        On the model I have started the designer calls for the small butane gas tank to be made from 1.5mm thick stainless steel sheet. My inclination though is to make it from silver soldered seventy thou brass sheet simply because I have piles of it.
        Maybe though, the designer knows something I do not regarding the unsuitability of brass for this purpose – do you?
        Rik
        #257498
        Pero
          @pero
          Rik
          I have seen brass used for this purpose before (including on professionally made tanks). It could possibly have been for strength for a particular design but quite possibly that was what the designer had in stock. Since nearly all the commercially made fittings for butane and propane are made of brass there is no question of the general suitability of brass for this use.
          Pero
          #257508
          John Rudd
            @johnrudd16576
            Just make sure that the strength test is carried out before putting into service…..
            #257517
            Rik Shaw
              @rikshaw
              "the strength test"
              Which one is that John?
              Rik
              #257522
                Much like a boiler you are making a pressure vestle so if playing with it in public you will have to get it tested and certified. Not sure of the numbers but its quite high, more than a copper boiler and higher than a lot of steel ones too.
                I'll have a look later as I know where there is a post that mentions the pressure.
                #257524
                  Posted by Rik Shaw on 23/09/2016 16:59:59:
                  "the strength test"
                  Rik
                  At room temperature butane liquefies at about 2.6 atm. The pressure will be higher if the tank gets hot. So the tank has to be made strong enough to resist the worst case pressure, which may be why the designer suggested stainless steel rather than brass.
                  I don't know if there's a formal test needed for a butane tank as there is for steam boilers. As people wander around with butane lighters made of plastic in their pockets, it can't be too difficult at least for a small one.
                  Jason posted first: he's more likely to know than me.
                  Edited By SillyOldDuffer on 23/09/2016 18:31:59
                  #257572
                  julian atkins
                    @julianatkins58923
                    I would make it out of thicker copper steam tube grade for the tube and all silver soldered up plus pressure tested on a boiler test rig. This is what I do on my lubricator displacement tanks for my hydrostatic sight feed lubricator systems on my locos. Quite a few of my locos had these tanks made out of high pressure bronze tubing ex RN. Sadly I've used up this supply but was lovely stuff.
                    Cheers,
                    Julian
                    #257588
                    Pero
                      @pero
                      I can't disagree with Julian about the need to test your gas tank for leaks at operating temperatures, but you need to keep in mind that the vapour pressure of butane is very low compared to the working pressure of even a small boiler. Two important considerations are that the vapour pressure increases as the temperature rises and also that mixtures of butane and propane have higher vapour pressures than pure butane, increasing as the propane fraction increases.
                      One reference indicates that at 90 degrees Fahrenheit the vapour pressure of pure butane is 29 PSI (presumably above ambient pressure [14.7 PSI at sea level] but this is not stated. The addition of a small amount of propane will increase the pressure significantly e.g. approximately double with the addition of 20% propane.
                      Pero
                      #257589
                      Keith Hale
                        @keithhale68713
                        As long as the joints are designed to operate in shear ie the components overlap and you get good penetration of the silver solder into the joint, you can expect a joint strength of 10 – 20,000 psi dependent on the joint gap.
                        The copper will fail before the joint!
                        It's one of the reasons you silver solder in the first place!
                        For more information go to http://www.cupalloys.co.uk/best-practice/
                        Keith
                        Edited By CuP Alloys 1 on 24/09/2016 08:54:35
                        Edited By CuP Alloys 1 on 24/09/2016 08:58:14
                        Edited By CuP Alloys 1 on 24/09/2016 09:00:37
                        #257590
                        Keith Long
                          @keithlong89920
                          Rik the following pdf from the Model Power Boat Assoc'n will tell you what pressure testing you need to do on a gas tank for a model. Covers 100% butane and the butane propane mixes as well – the pressure test is higher than you'd think.
                          Keith
                          #257597
                            Thanks Keith L. that saved me looking through a long thread to find the pressures.
                            Rik, this is the same thread and shows a copper gas tank being made which may be of interest, the actual talk of teh gas tank starts a page or two earlier but construction is part way down this page
                            Edited By JasonB on 24/09/2016 10:14:45
                            #257618
                            Rik Shaw
                              @rikshaw
                              Thanks to you all for the advice / pdf's / links, all of which I will carefully note when making the gas tank. I think I have a lot to learn about the properties of butane which is what I intend using (as in aerosol lighter fuel I am imagining).>>
                              At this early stage in my learning curve I am still puzzled for instance by the required test pressure in Keith's PDF of 210.50 psig when any smoker can carry a plastic container of the stuff in his pocket to light his fag! I would not have thought that a disposable plastic lighter would have withstood anywhere near that sort of pressure. So I must be missing something here!>>
                              As a school boy I was hospitalized in a science lab explosion. Here in my dotage I have no intention of taking risks and repeating the experience. Rest assured I will proceed with due caution.>>
                              Rik>>
                              #257628
                              John Rudd
                                @johnrudd16576
                                Rik,
                                The ciggy lighter thing and your gas tank build, the butane vp is goverened by a number of factors including liquid volume, temperature ambient and temperature max achievable….(external heat source e.g heat from your boiler)
                                There comes a point at which the vp cannot increase any further either by increasing the temperature or by lack of liquid volume allowing boil off…
                                Imagine a car engine, leave the rad cap off, the water will boil at 100C, replace the cap, increase the rad pressure, the boiling point goes up ( by how much? Take a look at steam tables )….
                                Edited By John Rudd on 24/09/2016 13:23:09
                                #257670
                                duncan webster 1
                                  @duncanwebster1
                                  Posted by CuP Alloys 1 on 24/09/2016 08:52:20:
                                  For more information go to **LINK**
                                  Keith
                                  This pdf is one of the best guides to silver solder I've seen. Should be compulsory reading for people making boilers!
                                  #257673
                                  John Rudd
                                    @johnrudd16576
                                    Duncan,
                                    Same applies to folk making gas tanks….wink
                                    ( myself included….)
                                  Home › Forums › Materials › Topics
