I've just purchased a second hand Axminster SX2 milling machine which I've just started to set up. One possible issue I've found is with the gas strut. I think it might be worn out as whilst it holds the head in its current position, it makes no attempt to raise it.
Can anyone confirm if the strut is supposed to lift the milling head, or it is only for holding in the current position?
I've confirmed that the head moves freely and having removed the strut, I've performed a crude experiment with my bathroom scales which shows the downwards weight of the milling head is about equal to the lifting strength of the strut.
