Fortis Vice
Fortis Vice
Home Forums Manual machine tools Fortis Vice
Viewing 11 posts - 26 through 36 (of 36 total)
  • #601133
    AJAX
      @ajax
      Posted by Rockingdodge on 09/06/2022 09:32:36:
      AJAX,
      Nice one, how did you restore it to it's current state, wire wheel?
      Do you plan to make jaws for it to use?
      Roger
      Yes, wire wheel on an angle grinder. The surface rust cleaned of easily. It was then wiped over with an oily rag (hence the slightly gloss finish) as I have no plans to repaint it now. I did one small repair/modification to make the quick release work correctly, and I will make some jaws when some suitable scraptonium comes my way. For now, it's just sitting under a bench.
      Michael Horley
        @michaelhorley72278
        Edited By Michael Horley on 09/06/2022 22:35:26
        #601171
        Michael Horley
          @michaelhorley72278
          This my Fortis with original paint.
          #601216
          Roger Clark
            @rogerclark
            Posted by Michael Horley on 09/06/2022 22:34:50:
            Fortis 11? Could do with a bit of tlc devil, pop it over to me and I'll take care of it for you wink
            #622622
            Geoffrey Rowland
              @geoffreyrowland97780
              I have a Furtis vice that has 10 cast into the bodies, but the jaws are only 4" wide. All the info I can find says No10 vices have 41/2" jaws. Anyone else come across this? Can't work out how to upload a photo yet. When I do I'll add a couple.
              #622630
              Oldiron
                @oldiron
                Posted by Geoffrey Rowland on 25/11/2022 12:03:27:
                Click on HERE to learn how to upload photos.
                regards
                #622635
                Geoffrey Rowland
                  20221124_163552.jpg20221124_163736.jpgHere are the photos to support my earlier post which should have read Fortis vice.
                  #622646
                  Bill Phinn
                    @billphinn90025
                    The replaceable jaws on yours may have been replaced with 4" jaws and the body of the vice angle-ground to remove damaged parts of the casting and make the new jaws look right. They don't look quite right, though, to me.
                    Edited By Bill Phinn on 25/11/2022 16:57:10
                    #622653
                    Geoffrey Rowland
                      Bill, thanks for your reply. I don't think it has been chopped about as the replacement jaws I sent for had the holes in the wrong place and also the casting around the bolt areas look correct.
                      #622655
                      Geoffrey Rowland
                        Here is a photo of a serial number I found stamped into the body when I first stripped it down. Not been able to find out anything about 20221107_134958.jpgit though.
                        #622657
                        Bill Phinn
                          @billphinn90025
                          Posted by Geoffrey Rowland on 25/11/2022 17:12:50:
                          I have sent my jaws to get some new ones made.
                          Geoffrey, I'm not quite sure what conclusion to draw from the replacement jaws you sent for having holes in the wrong place. It doesn't seem to me to say anything about the originality or otherwise of the jaws currently fitted to your vice.
                          The bolt hole areas of the casting won't have been affected if the projecting sides of castings where the jaws go have been slightly trimmed to make them line up with new shorter 4" jaws.
