First Lathe
First Lathe
Home Forums Manual machine tools First Lathe
Viewing 25 posts - 1 through 25 (of 31 total)
  • #422923
    Nathan Turner 1
      @nathanturner1
      Hello everyone i'm currently searching for my first lathe, for a variety of work, some stationary engines, steel tooling for the shop and some smaller mechanical work. I already have a milling machine, tool and cutter grinder plus some other bits and pieces that would make me semi-comfortable to buy used and repair things. The space i have available is roughly 170cm L x 80cm W. My wishlist currently is:
      Camlock chuck
      metric
      fairly complete threadcutting gearbox
      around 300kg max (can go higher this is mainly incase i want to sell or move the lathe and not restrict potential buyers)
      good size spindle bore, perhaps 38mm
      10×20 inch capacity minimum, the swing is more important to me
      ideally quiet running (am quite happy to fit vfd and motor but if theres a model already with it then that's a plus)
      would like to spend around £3k at most but would spend more if there are much better alternatives out there.
      If i look at new machines that fit the bill i can only see the chester crusader and warco gh 1236 which are pretty big for me (warco have sold all the next batch of 1230) and emvio engineering has the eml-290 which has the inverter and d1-4 taper at a minimum of £2.2k.
      With used machines i'm really not knowledgeable but the Emco maximat super 11 cd seems to fit the bill perfectly and then i've not seen much else, ideas ?
      thanks in advance for any replies
      Edited By Nathan Turner 1 on 06/08/2019 17:46:56
      Nathan Turner 1
        @nathanturner1
        #422927
        old mart
          @oldmart
          That EML290 looks good, I see that a DRO is optional, which may well be within your budget.
          #422931
            That does not really have a screwcutting gearbox.
            It is the same as the Warco etc 280 & 290 models where you get a simple 1:2, 1:1. 2:1 gearbox that gives 3 pitches per change wheel setup eg if you set for 1mm pitch you can also get 0.5mm and 2mm without changing anything. You will have to change the gear train each time you want to go back to a fine feed.
            I think SPG also did it at one time with the camlock spindle.
            #422932
            Thor 🇳🇴
              @thor
              Hi Nathan,
              I have an older 290 lathe with 38mm spindle bore and MT3 tailstock. It has served me well for 6 years. The EML290 you mention look very similar to mine except for the Camlock spindle nose (and the paintwork of course). A Camlock spindle nose was on my wishlist but I wasn't able to find one where I live.
              Thor
              #422935
              Nathan Turner 1
                @nathanturner1
                Thankyou for the replies. JasonB, it's one thing that puts me off it, i was hoping there was perhaps something like the emco maximat 11 that another company had made that i could search for used.
                Thor, i think they seem to be pretty similar. I actually looked at the warco 280 as the 290 seems to be fairly pricey from them at the moment but i'd like the camlock. What kind of work have you mainly done with it ?
                old mart, i forgot to add a DRO to the list, i wouldnt be without one on my gh universal mill from warco. I'll probably fit my own as the extra markup for prefitting seems to be quite high and it was fairly straightforward on the mill
                Edited By Nathan Turner 1 on 06/08/2019 18:55:34
                #422940
                Former Member
                  @formermember32069
                  #422941
                    There is a Super 11 CD in the classifieds at the moment
                    #422943
                    Nathan Turner 1
                      @nathanturner1
                      Thanks Barrie the wabeco does look very good i think the price is just a bit too far out of my range. JasonB i've actually contacted him and he's sold it unfortunately but wasnt aware of how to remove the ad, i'm kicking myself for not seeing it quick enough so i'll haveto keep searching
                      Barrie ive found three Maximat V10P lathes on ebay just now, i'll haveto read up on how they compare to the 11. the most expensive actually looks in ok condition but is too far for me to visit without buying blind. There is one in Nottingham which i could see, they want £1200 for it, looks well used so i'm unsure but could be worth considering, thanks
                      Edited By Nathan Turner 1 on 06/08/2019 19:53:48
                      #422950
                      Former Member
                        @formermember32069
                        #422955
                        David Standing 1
                          @davidstanding1
                          If you are looking at Warco, why haven't you mentioned the GH1322?
                          Bigger swing than the two you mentioned, smaller footprint, and if you want a metric 3 phase one, and you say you can fit a VFD, it has the benefit of currently being £650 off!
                          #422967
                          Nathan Turner 1
                            @nathanturner1
                            Hi David, i had seen this and completely forgotten about it. It's on the heavy side but is in stock at least plus the gap bed could be useful for future use. With a dro vfd and 3 phase 240v motor it might come in a bit above my target price but it has a lot going for it. Does anyone on the forum have this model to share their experience ?
                            #423097
                            Thor 🇳🇴
                              @thor
                              Posted by Nathan Turner 1 on 06/08/2019 18:41:49:
                              I have turned small steam engines, 150mm dia. steel backplates, hard steel bars, light alloy and brass, it works well for the work I do. If you can get an Emco 11 in good condition, buy it.
                              Thor
                              #423101
                              Old School
                                @oldschool
                                What about a Myford 254S the metric ones are cheaper than the imperial ones. Only secondhand machines now. Very happy with mine.
                                #423106
                                  Posted by Nathan Turner 1 on 06/08/2019 19:21:37:
                                  For future reference, when you are logged in, go to the 'more for sale ads' page and click 'manage my ads'.
                                  David Standing 1
                                    @davidstanding1
                                    Posted by Old School on 07/08/2019 18:02:28:
                                    Nathan's brief included 'good sized spindle bore, perhaps 38mm'. A 254S misses that brief by 12mm wink
                                    #423148
                                    Former Member
                                      @formermember32069
                                      #423150
                                      not done it yet
                                        @notdoneityet
                                        BL,
                                        Also misses that 10” minimum swing. How many 254 machines had camlok spindles? Not many, I would have guessed, but as always I may be wrong!
                                        If that lathe were to be an option, a good Raglan 5” might be an alternative (but only with a L-100 spindle nose?). About as rare, I would think! But a good Raglan 5” might cost a third, or less, than a 254!
                                        Making tight specifications, as a requirement, invites an expensive price tag – but it is only a ‘wish list’, after all.
                                        #423152
                                          Posted by Barrie Lever on 08/08/2019 07:55:03:
                                          Posted by David Standing 1 on 07/08/2019 21:11:49:
                                          I would allow slip on the 38mm requirement to be the owner of a Myford 254S, ways can be found to get around that requirement, unless it was an everyday occurrence.
                                          B.
                                          Many moons ago when people paid me to evaluate competitive bids, before issuing tenders we carefully categorised Requirements as either Mandatory and Desirable. Failure to meet a Mandatory would be enough to reject a bid no matter how good it was otherwise.
                                          Treatment of Desirable requirements was more complicated in that they were scored and weighted to establish objectively just how important they actually were relative to each other. By comparing the total weighted scores, it was possible to identify which bid best met the requirement. The system reduces personal bias and – because it is objective – the decision can be defended if challenged.
                                          Nathan's question described his requirements as a 'wishlist', that is everything is desirable. As so much is up for grabs, it's tricky for the forum to advise because we can't tell what matters or not. Possibly before choosing a lathe, Nathan needs help refining his list of requirements. (Apologies to Nathan if he knows exactly what he wants and why!)
                                          It's worth putting a bit of thought into requirements because getting them wrong can be wasteful. For example, if Nathan has a mandatory requirement for a 38mm spindle bore, then the excellent Myford 254S is not for him. On the other hand, if 38mm is a convenience feature, then it can be scored relative to other convenience features.
                                          Apart from spindle bore the other difficult requirement in Nathan's wish-list is that Camlock chuck. As a mandatory requirement camlock severely restricts Nathan's choice of lathe. No problem with wanting one if Nathan will be constantly changing chucks, but a seriously bad idea if the Camlock feature is lightly used. It's because specifying camlock eliminates many good alternatives, cheaper and/or better lathes, which is undesirable because Nathan has restrictions on size, weight, swing and budget as well.
                                          Former Member
                                            @formermember32069
                                            #423160
                                            Hollowpoint
                                              @hollowpoint
                                              Personally I would go secondhand. Your budget gets you into Harrison, Colchester, Boxford territory and while you might not get every feature you want the overall quality of the lathe will be superior. I can say that as someone who has owned both British and Chinese lathes.
                                              #423162
                                              not done it yet
                                                @notdoneityet
                                                Well set out Dave. About my thoughts, above. I just added a cheaper, probably better alternative to the 254. Larger swing (at least an extra 1/4”, at 10 1/4” +. Note that myford quote swing as more than twice centre height), slightly larger spindle bore, possible (but not so likely) metric lead screw, larger motor and an extra 4” between centres among other similarities.
                                                Add a 3 phase motor with VFD, plus DROs and most lathes are basically ‘metricated”. Certainly far better value than any 254 sale items I have seen, but it doesn’t appear that Nathan wants to save dosh (looking at the ‘wish list’ and budget) or looking at specs quite as low as these?
                                                #423174
                                                Howard Lewis
                                                  @howardlewis46836
                                                  If you are prepared to look at useed machines of far eastern origin, a used Warco BH600, Chester Craftsman, EngineersToolRoom BL12-24 would tick most of the boxes in your wish list. They will swing 12" over the bed, 18" in the gap, have hardened bedways, and 38mm bore Mandrel, and PCF . The Norton Gearbox provides 40 possibilities, and can be used to cut Imperial or Metric threads. They weigh 300 Kg, and should come with 3 and 4 jaw chucks, Faceplate and steadies. The chucks are screw on, but are retained by dogs, for reverse running. With back Gear, 12 speeds are available. A VFD would make one even more versatile.
                                                  No doubt their GH sucessors have similar specs.
                                                  If you want new, Don't know the spec, but would a Seig SC6 meet your requirements? Possible supplier? Axminster?.
                                                  PS
                                                  Make allowance in your budget for tooling and measuring equipment!
                                                  Edited By Howard Lewis on 08/08/2019 12:17:34
                                                  #423190
                                                    Posted by not done it yet on 08/08/2019 10:06:34:
                                                    Which is not unreasonable
                                                    It should be true of many lathes [depending upon the bed profile]
                                                    not done it yet
                                                      @notdoneityet
                                                      Posted by Michael Gilligan on 08/08/2019 18:06:44:
                                                      Are all the Chinese mini lathes the same? I only mentioned it because Raglan only quoted centre height (already over 5&rdquo and not total swing available. The instruction manual indicates 3 3/8th” gap between the shears. The swing could obviously be calculated from that but I thought it unnecessary. Still do.
