“Fanstock Clip-rivit” what is it?
Home Forums General Questions “Fanstock Clip-rivit” what is it?
  • #194911
      I have just got another set of castings and on one of the parts it says to use a "Fanstock clip-rivit" which I have never heard of and it seems neither has Google, does anyone know what they are (its a US engine if that helps)
      The part it refers to is the thin brass bit of the rear of the rivit mid way along this spring steel strip on the full size engine
      Thanks in advance, J.
        Keith Long
          @keithlong89920
          Jason – try an alternative spelling -"fahnestock".
          Fahnestock clips are some sort of "vintage" electrical connector – does that make sense?
          #194915
          MichaelR
            @michaelr
            Jason, Try Fahnestock Clip or see Here **LINK** not sure if it will be of help, it's some sort of electrical connection.
            #194916
            john swift 1
              @johnswift1
              Hi JasonB
              I've seen fahnestock clips use on old american valve(tube) radio's
              have a look at
              https://www.tubesandmore.com/products/S-H11-4043-6
              john
              Edited By john swift 1 on 25/06/2015 19:51:12
              #194917
              Martin Cottrell
                @martincottrell21329
                Just beat me to it Keith! Fahnestock clip used to secure the bared end of an electric cable.
                Regards Martin.
                #194918
                  Thanks Chaps that looks like it and yes it takes one of the electrical contacts to complete the ignition circuit
                  #194920
                  Nigel McBurney 1
                    @nigelmcburney1
                    Commonly used on the igniter on vintage Amanco and other stationary engines,made of brass and longer than the clip in the photo above,to fit the wire (from the magneto) the the clip is pressed and the wire inserted into the pressed vee,
                    #194937
                    Roderick Jenkins
                      @roderickjenkins93242
                      That looks like the perfect thing to make out of BeCu – springy and a good conductor.
                      Rod
                      #194941
                        I think I have a small offcut left over from the electrical contacts on another hit & miss engine, funny enough it was another Monitor engine, this one is for the small 1 1/4HP VJ Monitor (vertical jack)
                        #194946
                        John McNamara
                          @johnmcnamara74883
                          Yes it was sometimes used on the back of old radios to attach a battery or an Arial wire.
                          Gee have not seen one since I was a kid.
                          Mr Google likes plain English
                          This was my search:
                          vintage radio battery brass clip
                          Martin Kyte
                            @martinkyte99762
                            They are also found on synchronome slave clocks.
                            Martin
                            #194966
                            Ian S C
                              @iansc
                              Used to be used(by me)for aerial and earth, and head phone connections on crystal sets, used to get them off old 1 1/2 v telephone batteries, the big one about 6" high by 2 1/2" diameter. Some of the kits by Dick Smith(Australia) were wired up with Fahnstock clips, I think there are still a few around here, although I gave most of them the a mate with old hit and miss engines.
                              Ian S C
                              #194980
                                Hi Jason:
                                Let me google that for you
                                To be fair, google offered me the corrected spelling. and its a Fahnestock clip that is used with a rivet, not a 'rivet clip'.
                                en.wikipedia.org/wiki/Fahnestock_clip
                                Can't believe I beat Michael G. to that one ;&#39
                                  I was only going by what it said on the drawing Neil, can't help that the guy who did the drawings, patterns and castings knew what the item was called but not how to spell it.
                                  The hyphen between Clip-rivit was now obviously meant rivit the clip in place though no rivit is shown on the drawing and only the photos I posted give an indication of that.
                                  I'll probably end up making one as it would only want to be about 1/8" wide
                                  #194988
                                    Shows what happens if you load a page and then go out for four hours, too!
                                    mark costello 1
                                      @markcostello1
                                      Also used on a Briggs and Stratton Lawn mower engine, if You have equivalent " across the pond."
