Facing parallel between centres.
Home › Forums › Beginners questions › Facing parallel between centres.
Viewing 25 posts - 1 through 25 (of 70 total)
  • #10437
    Robin Graham
      @robingraham42208
      #495495
      Robin Graham
        @robingraham42208
        I've posted recently about turning risers for VMC mills. The biggest new challenge for me was getting the ends of a 4-5 inch long 6 inch diameter round bar parallel using a lathe.
        I got to about half a thou over 6" diameter / 4" long by bolting to a faceplate – I was quite pleased with that, and I expect it'll be fit for purpose.
        However, the advice I had here was that the best way to do this is between centres. I tried that on a 4" diameter test piece and it came out about 1.5 thou wrong over the diameter.
        I'm confused! I'm pretty bad at visualising things in 3D, but I think that even if the head and tail stock centres are misaligned the faces should end up parallel. That is turning the work end for end and facing at the tailstock end. I might well be wrong though!
        Any advice would be welcome – I'd like to track this down.
        Robin.
        Edited By Robin Graham on 13/09/2020 00:04:23
        Edited By Robin Graham on 13/09/2020 00:05:00
        #495498
        Ady1
          @ady1
          Posted by Robin Graham on 12/09/2020 23:38:33:
          However, the advice I had was that the best way to do this is between centres. I tried that on a 4" diameter test piece and it came out about 1.5 thou wrong over the diameter.
          Robin.
          4 inches, between centres
          Did you use a gigantic lathe dog?
          edit: if you used chuck jaws this can introduce errors
          very light cuts with a very sharp tool reduces distorting forces at the tailstock end
          Between centres work can be exceptionally difficult on a hobby machine
          Edited By Ady1 on 13/09/2020 00:15:34
          #495500
          Robin Graham
            @robingraham42208
            Well, I do have a gigantic dog who sometimes who watches me me turning, but I've yet to put her onto workholding duties. Luckily the nature of the work allows a drive pin in this case.
            Robin
            Edited By Robin Graham on 13/09/2020 00:20:05
            #495501
            blowlamp
              @blowlamp
              Are you talking about the top and bottom (end) faces being out of parallel or a variation in diameter between each end?
              If it's the diameters that differ, then you need to adjust the tailstock to correct the slight error you have. However, if you can reverse the workpiece end for end between cuts at the tailstock end only, then you should be able to get a better result, as long as you don't disturb the cross slide setting between those cuts.
              How is the parallelism over the 4" length?
              Martin.
              #495502
              Ady1
                @ady1
                If your faceplate work was right on the money with a tailstock centre and the only change was to place the work between centres then it must be your positioning between centres and/or the cutting forces used
                For really accurate hobby stuff I always use a well lubricated dead centre in the tailstock
                The faceplate job only needed pushed and relatively little support but the between centres job will need a decent support hole at each end
                Edited By Ady1 on 13/09/2020 00:34:31
                #495503
                Robin Graham
                  @robingraham42208
                  Posted by Ady1 on 13/09/2020
                  Can you explain that further Ady? What are the problems?
                  Robin.
                  #495506
                  Hopper
                    @hopper
                    You need to set your tailstock offset adjustment so that it is turning dead parallel along the outside diameter of the job or a test peice before facing the ends. Otherwise, the ends will be conical to some extent. Trouble with old/cheap lathes is the tailstock can go out of line every time you move it or even tighten the barrel clamp.
                    The other factor with old/cheap lathes is the cross slide may well be cutting out of square to the main lathe axis, also giving a conical face to some extent.
                    Definitely +1 on use a dead centre in the tailstock, not revolving, for high precision work. Hobby grade revolving centres can be all over the place.
                    If you have already got with in half a thou over six inches, that is about as accurate as you can expect on a typical lathe. In industry, tolerances of less than a thou are usually done on grinding machines which are of a next-grade accuracy.
                    Edited By Hopper on 13/09/2020 00:50:06
                    #495508
                    Ady1
                      @ady1
                      Any error whatsoever will be reflected in the finished workpiece, from setup to completion
                      Proper between centres turning if done right allows you to remove the workpiece for other work to be done and then return it to the lathe, swapping the bar end for end if you want to, it gives accurate repeatability
                      but everything has to be really spot on, the man the machine and the setup, it's a highly skilled man who can knock out good between centres stuff (not me lol)
                      Edited By Ady1 on 13/09/2020 00:59:38
                      #495509
                      Emgee
                        @emgee
                        Robin
                        Did you turn and face both ends between centres, or just face one end ?
                        You did well to achieve such accuracy with the 6" diameter piece, did you check to see if the end faces were square to the length, as a cylindrical square ?
                        Emgee
                        Edited By Emgee on 13/09/2020 01:01:43
                        #495510
                        Ady1
                          @ady1
                          As an example, one of your posts mentioned the workpiece was up to 68 degrees when finished
                          So the workpiece expands and contracts between the centres if it gets too hot
                          #495514
                            Robin.
                            Your visualisation of this process seems fine, Robin … but I fear that what you are physically doing may not meet its rules.
                            It is theoretically possible to achieve perfect parallelism of the two end faces by swapping the workpiece between dead centres [i.e. like the bodger’s pole-lathe, or the watchmaker’s turns] … it is ‘simply’ a matter of taking a ‘perpendicular to the axis’ cut twice.
                            In practise, however, there may be variation from that idealised situation:
                            • Your cross-slide action may not be precisely repeatable
                            • Your centres may be constraining the work to not rotate on two hypothetically pure points !
                            On that second bullet … I have previously been ridiculed for suggesting that someone should consider the action of ball-ended centres, in comparison to cones, but it is a useful ‘thought-experiment’
                            Edited By Michael Gilligan on 13/09/2020 06:50:45
                            #495515
                            John McNamara
                              @johnmcnamara74883
                              One way to face two sides perfectly that has worked for me in the past is to:
                              First face the work piece both sides in the three or 4 jaw it does not mater. then drill and centre one side of the workpiece.
                              When you take the workpiece out of the lathe chances are that it will be a little out of parallel even if you set it up with a dial indicator, it will probably be a few tenth's out.
                              The next step is to place a piece of scrap in the lathe and then face the outer edge say 10mm then turn a recess in the centre say 10 thou deep. leave this piece in the lathe. It will be perfectly true.
                              ithin the limits of the spindle bearings If you want to be technically correct.
                              Then hold the non centred side of the workpiece and centre it up with the tailstock centre pressed firmly against it and locked. This process works better with a ball bearing centre. Another possibility would be to bolt it through the spindle to keep it pressed against the fresh turned surface.
                              The last step is using a fine light feed face the centred side, you will leave a small unfinished section in the centre, this can be removed with a file if need be. You should not need a dog if the workpiece is a reasonable diameter. friction will hold it
                              The method also gives limited access to the back and all the side of the disk. Probably enough to do a riser in one sitting. if you plan it well.
                              Peter Krogh
                                @peterkrogh76576
                                A plane is defined by three points in space. Two points make a line…..
                                Getting the centers sooooo close that one could 'flip' the part between the centers and have exactly the same plane????
                                That's what face plates are for……
                                Pete
                                #495521
                                Hopper
                                  @hopper
                                  Posted by Michael Gilligan on 13/09/2020 06:47:04:
                                  Robin.
                                  No. The below exaggerated view shows how if the axis of the job is offset at an angle to the axis of the lathe, the previously faced ends will now be also at an angle. Imagine, if you will, now taking a facing cut on the pictured example, a cut that is square to the lathe axis. The end of the job will be conical as the cut is square to the lathe axis but not square to the job axis.
                                  Edited By Hopper on 13/09/2020 07:36:56
                                  #495522
                                  pgk pgk
                                    @pgkpgk17461
                                    Posted by Hopper on 13/09/2020 07:35:04:
                                    But the ends will still be parallel within the vagaries of machine 'slop' and any possible errrors in flipping the piece?
                                    Since this part is a bearer that only has to be parallel on it's circumferences then why not just stick a hefty stud into the center of each end and set it up between a chuck and tailstock such that both ends can be faced inwards as much as needed for the circumferential bearing surfaces without flipping the part and then remove studs, bore outwards on each face just below that bearing depth. The only variation you have is slop between left and right facing actions.
                                    pgk
                                    #495523
                                    Pete Rimmer
                                      @peterimmer30576
                                      Whilst that is true the practicalities are that for bringing two clamping faces of a riser parallel, eye-balling the points will be sufficient.
                                      The most likely source of error is that the live centre was not turning on axis.
                                      Robin you should put your centre in the spindle and set a DTI on the side near the point. It must not have any runout.
                                      #495524
                                      Hopper
                                        @hopper
                                        Posted by pgk pgk on 13/09/2020 08:21:53:
                                        No. The ends will  be conical if you cut straight in square to the lathe axis while the job axis is at an angle to the lathe axis. The ends in the illustration are parallel, but they were turned BEFORE the tailstock was offset in this taper turning example. If you now face the tailstock end of the job, it will be a convex cone. If you then flip the job end for end and face the other end, it too will be convex. Two convex surfaces are never going to be parallel.
                                        Edited By Hopper on 13/09/2020 08:32:48
                                        #495525
                                        Pete Rimmer
                                          @peterimmer30576
                                          Posted by Hopper on 13/09/2020 08:29:32:
                                          The faces will not be parallel but the ends of the part will be co-planar which is the desired result.
                                          #495527
                                          not done it yet
                                            @notdoneityet
                                            The problem the OP had with the face plate thread was that he did not give the full details for the end product.
                                            Drilling holes in the ends of the part and bolting the part to the faceplate would have been the easiest and most obvious way to do it (as opposed to one thin bolt through the centre). Same as facing the ends – there is only about 3cm around the circumference that actually needs to be parallel – and (clearly now) one of those was not needed to be done until the spigot was completed.
                                            The boring, for the spigot, certainly could not be carried out between centres, for sure.🙂
                                            Order of operations and any later covered-over ‘setting up for machining’ holes were simply not considered before starting the machining – as far as I can tell. Like there are three holes, for bolts on a PCD, required at some point? I would likely have made those after facing the first end!
                                            Tailstock does not need to be moved between turning the part between centres – just wound back a cm or so to clear the centre at one end. We don’t even know how all these measurements were taken, and the precision is likely as good, or better, than the original machine anyway.🙂
                                            That leaves three possible positions for the spacer to be fitted – meaning that should there be the tinyist allignment out-of-true, there would first be a choice of turning the spacer by 120 degrees or Possibly skimming one face by a hundredth of a mm or so. No real sweat on the whole job ,whose length is not actually a critical dimension.
                                            This lot, above, is the result of hindsight. But unnecessary if some fore-thought had been given to the job before starting, I feel.
                                            #495531
                                            Hopper
                                              @hopper
                                              Posted by Pete Rimmer on 13/09/2020 08:44:36:
                                              Both faces will be convex. Call it what you like. Try perching your mill column on top of a disc with convex faces top and bottom and see if it acts like a ball joint or not.
                                              #495532
                                                Robin’s previous thread on this matter went quiet after I commented [and blowlamp endorsed]:
                                                For best results when turning between centres, you will [obviously ?] need to switch the workpiece end-for-end, rather than changing tools and saddle position. … You want both faces to end-up either flat or very slightly concave.
                                                So we can hope that Robin accepts this … and his opening post here suggests that he does yes
                                                Ref.https://www.model-engineer.co.uk/forums/postings.asp?th=167097&p=2
                                                Edited By Michael Gilligan on 13/09/2020 09:54:13
                                                #495541
                                                Pete Rimmer
                                                  @peterimmer30576
                                                  Robin says he is using a drive pin. Presumably this is drilled into the face. If that is the case he should have access to both ends in the same setup. You can't beat that. The rotation of the part on axis is the most critical aspect. I don't see the relevance of tool changing or saddle location.
                                                  #495542
                                                  Hopper
                                                    @hopper
                                                    Posted by Michael Gilligan on 13/09/2020 09:52:59:
                                                    Ref.**LINK**
                                                    We have no way of knowing what Robin has accepted or done. But he does say in the first post of this thread that he can't visualize how an offset tailstock could cause the two end faces to be other than flat and parallel. My example illustration above is simply to help him visualise what is going on. Seems like quite a few others are having the same difficulty envisioning it. Anyhows, conical end faces may or may not be responsible for the variation in mike readings across the two faces. More testing and reporting back is required.
                                                    BTW Robin, how are you measuring the distance across the two faces? A 4" micrometer or with a dial indicator and stand on a surface table?
                                                    #495548
                                                      Posted by Hopper on 13/09/2020 10:25:52:
                                                      dont know
                                                      [quote] That is turning the work end for end and facing at the tailstock end. [/quote]
