Extending thread on stainless steel bolts
Home Forums General Questions Extending thread on stainless steel bolts
Viewing 23 posts - 1 through 23 (of 23 total)
  • #215393
    William Pascoe
      @williampascoe49138
      Hi All,
      A friend has asked me to extend the thread on some M12 304 stainless steel bolts. 98 bolts by 20 mm and 98 by 80 mm. So I'm looking for a quick method. Any advice on the best method would be appreciated. My experience with stainless is that it blunts cutters quickly.
      Cheers
      Bill Pascoe
      William Pascoe
        @williampascoe49138
        Threading stainless steel
        #215396
        Tony Pratt 1
          @tonypratt1
          Decent sharp die also use cutting fluid.
          Tony
          #215399
          Peter Neill
            @peterneill47196
            Politely say no.
            You'll probably spend more money on replacing multiple worn-out HSS dies than the favor will be worth, you'll also end up with hands that are blistered for weeks and wrists that are too sore to even raise a pint glass.
            Hiding-to-nothing is a phrase that immediately springs to mind.
            Peter
            #215402
            David Jupp
              @davidjupp51506
              That sounds like a significant favour – more of a production run.
              Check if the bolts are to be used for anything critical, especially if likely to be subjected to cyclic stresses – cut threads won't match the fatigue performance of the original rolled threads.
              #215403
                Check the shank dia they may have been rolled so there won't be enough metal to cut a thread
                #215409
                old Al
                  @oldal
                  Im with Peter Neil.
                  The threads would have work hardened when they were made and running a die down them again will blunt dies quicker than anything, even with the best of fluids.
                  Sounds like a good earner, but their will be tears.
                  #215418
                  Ian S C
                    @iansc
                    I'm with Peter and Jason, it's unlikely that you will get a serviceable bolt, might be ok if you want to hang a gate. Get some stainless "all thread", and put a nut on each end. If one end must be a bolt, Loctite the nut on that end(shaft lock).
                    Ian S C
                    #215426
                    William Pascoe
                      @williampascoe49138
                      Thanks ever one. Thinking about this I also came up with the thread rod idea which I have put to my friend.
                      Cheers
                      Bill
                      #215428
                      Involute Curve
                        @involutecurve
                        Invite him into your workshop, hand him a tap wrench etc. also have a price list for quality dies on the bench and see how long he lasts. smile p
                        My bet is 5 min…………
                        Before he runs off get the cash for the die he's wrecked……..
                        Shaun
                        Edited By Involute Curve on 07/12/2015 10:31:36
                        #215439
                        colin hawes
                          @colinhawes85982
                          You will ruin your dies. Colin
                          #215444
                          mechman48
                            @mechman48
                            I'm with Peter & Ian SC… politely refuse.
                            George.
                            #215455
                            Chris Evans 6
                              @chrisevans6
                              Just persuade him to buy hex head set screws, they are threaded to the head.
                              #215466
                              KWIL
                                @kwil
                                Perhaps they are all bolts to him!
                                #215488
                                Anonymous
                                  Are you sure they're 304 ? Has someone made them because the majority of commercial bolts are A2 or A4. If they're A2 then it's no problem to add thread if the shank is the right diameter if they're A4 then forget it. Done loads of rethreading A2 when I needed the right length of plain shank of a longer bolt, a decent HSS die lasts a fair bit on A2. Just get your mate to do it under your supervision though for that many.frown
                                  #215494
                                  Peter Neill
                                    @peterneill47196
                                    Mick – A2 is 304 and A4 is 316, and quite frankly I've always found 316 easier to machine than 304 at any time.
                                    Without casting aspersions, a lot of 'stainless' fasteners these days come from China, and I have seen some terribly soft metal used there, as well as some that behave as expected. But re-threading a stainless bolt is not an easy task, so I'll have to beg to differ with your view of 'no problem'
                                    Peter
                                    #215516
                                    Anonymous
                                      Thought A2 was 304L not just "plain" 304 as I've never had a problem with reworking A2 fixings compared to machining/threading 304 barstock.
                                      #215522
                                      Peter Neill
                                        @peterneill47196
                                        The 'L' when added to stainless always means low carbon (for easier welding) not added lead, so 304 is just 304 and not easier machining like the free cutting mild steels with lead added.
                                        I reckon you must have had the Chinese A2 bolts Mick
                                        #215557
                                        Ian S C
                                          @iansc
                                          Most stainless bolts are(in my experience), 316, as this is the grade use in marine work, you might find suitable bolts at a Ships Chandler's.
                                          Ian S C
                                          #215576
                                          daveb
                                            @daveb17630
                                            I have extended the thread on large bolts, high tensile and stainless, over 8mm I always screwcut and finish off with a die.
                                            #215635
                                            William Pascoe
                                              @williampascoe49138
                                              Thanks for all your help. The thread rod suggestion has been excepted.
                                              Cheers
                                              Bill
                                              #215639
                                              John Haine
                                                @johnhaine32865
                                                Does that mean this thread won't be extended?
                                                #215722
                                                peak4
                                                  @peak4
                                                  The price seems to vary wildly depending on where you go. Builder's merchants might be cheaper than nut and bolt suppliers, as it's used for chemical anchors.
                                                  Toolstation do it for 6.72 per metre which is a good starting point to work from;
