Emco Compact 5
Emco Compact 5
Home Forums Manual machine tools Emco Compact 5
Viewing 25 posts - 26 through 50 (of 57 total)
  • #388052
    Chris Trice
      @christrice43267
      Strip of gauge plate would be my choice.
        One just come up for sale down the right in classifieds., hope the price is a typo.
        #388064
        Russell Eberhardt
          @russelleberhardt48058
          Posted by JasonB on 29/12/2018 07:02:42:
          That's the solid gold version with the diamond bearings!
          Russell
          #388076
          Graham Meek
            @grahammeek88282
            The Gib plates on the Unimat 3/4, Compact 5, Compact 8, rear of Compact 10 and the rear of the Maximat Super 11 are all made from a glass filled plastic. The mounting surface that this Gib sits on is lower than the mating "Way" surface. This provides for a constant force on the Gib and removes play.
            The Gib on the rear of my Maximat has been tightened twice since I purchased it in 1986. I have a spare Gib bought at the same time but have never needed to use it. The loading on these Gibs should be hardly anything with a prismatic bedway.
            Turning the plates over from end to end would be a good idea, but given the wear resistance characteristics and rigidity properties of the original material I would not substitute them for some other plastic.
            Blunt tooling and overloading the machine will give a poor finish. As Jason said earlier you are not going to remove large amounts of material like a larger lathe. It is all a question of rigidity.
            Gray,
            #388089
            Former Member
              @formermember32069
              #388094
              Mick B1
                @mickb1
                Posted by Barrie Lever 1 on 29/12/2018 12:49:38:
                The EMCO machines were designed and manufactured by proper engineers who really understood their business, however the market changed and their locality cannot support low cost manufacture. The desirability and quality is still appriciated as can be seen on Ebay when plus 30 year old Unimat 3's and Compact 5's change hands for more money than new Chinese mini lathes.
                Regards Barrie
                That's certainly true. Nevertheless the current Unimat 3 clone – Sieg C0 – is not materially inferior in quality, and has some real advantages like stepless speed variability and 67% more motor power.
                It also doesn't destroy drive belts at the rate my Unimat 3 used to… laugh
                Edited By Mick B1 on 29/12/2018 13:37:16
                #388107
                Graham Meek
                  @grahammeek88282
                  A slight inaccuracy in my last post. The Compact 8 only has the plastic Gib at the rear, like it's big brothers.
                  On the question of costs, my Maximat machine is the same price today second hand as what I paid for it new in 1986. While the Compact 5 has doubled in value from the second hand price paid 15 years ago, even though the lathe had never been taken out of the box.
                  Gray,
                  #388162
                  mike T
                    @miket56243
                    Gray, Barrie and everyone.
                    Thanks for the advice regarding the plastic gib plates on the Compact 5 and other Emco machines. It is good to know that design is basically sound and does not need to be 'fixed'.
                    My machine is the CNC version with the lathe bed bolted to a sheet steel structure, it's not easy to remove the lathe to get access to the gib plates to make adjustments. So I attempted to make the adjustments in situ.I shortened a standard Allen key to fit, and with the aid of spot lights, inspection mirrors an a lot of rude words, I was able to reach up into the lathe bed to adjust the gib plate screws. Getting the Allen key to line up with the screw heads, when everything is upside down, back to front and barely accessible, was an interesting challenge in itself.
                    The three screws under the rear flat bed way, were already tight and did not need adjustment. The four screws for the forward gib plate, under the 'V' bed way, were a different story. One of the screws was missing completely and a replacement had to be found. The remaining three screws all needed about 3/4 of a turn to tighten the gib plate under the forward bed way.
                    These gib plate adjustments were difficult to do with the lathe bolted down, but possible; just. A complete transformation was achieved, the lathe and carriage are now correctly adjusted (for the first time in years) with no discernable play, even when I push and pull on the overhanging stepper motor. My Compact 5 CNC lives to fight another day.
                    Jobs a good 'un.
                    Thanks again for all the help, advice and encouragement.
                    Edited By mike T on 29/12/2018 20:39:06
                    #388181
                    Chris Trice
                      @christrice43267
                      Glad it's sorted. I always like to ask myself why things are loose when I buy something but it sounds like you've sorted it. I'm very interested to see how you get on with the CNC side and your opinions of lathe.
                      #388213
                      Kiwi Bloke
                        @kiwibloke62605
                        Well, I never expected there to be so much discussion about this machine. Thanks everyone for all the information and opinion. It all sounds quite encouraging.
                        An apparently very little-used example, complete with milling head, collet chucks, collet set, 3-jaw, 4-jaw, topslide, steadies, change wheels, dividing unit, and a few other bits and bobs recently sold here (NZ) for about NZ$2,500 (divide by 2 for pounds) – the same as a well-equipped, little-used, Cowells 90ME made. Emco gear is fought for here. Just out of interest, what would these machines go for in UK?
                        Quick question – it's not uncommon to see Cowells equipment sold in almost new condition: what's going on?
                        #388219
                        Former Member
                          @formermember32069
                          #388242
                          Emgee
                            @emgee
                            Posted by Chris Trice on 29/12/2018 22:15:29:
                            Chris,
                            Emco Compact 5 cnc working in this video  https://youtu.be/37HZELzhkDE
                            shows turning, radius cuts, taper cut and threading.
                            Many more videos showing the same machine on different jobs at the same channel.
                            Emgee
                            Edited By Emgee on 30/12/2018 10:38:27
                            Edited By Emgee on 30/12/2018 10:43:27
                            #388243
                              Posted by Kiwi Bloke 1 on 30/12/2018 08:51:04:
                              My guess is Cowells appeal chiefly to clockmakers and the like who tend to use theri machines lihtly and take great care of them.
                              Nweil
                              #388248
                              Graham Meek
                                @grahammeek88282
                                The Cowells lathe started life as the Perris lathe, marketed by Brian Perris. Which could be purchased in kit form circa 1973 for the princely sum of £29.00. At that time the machine used the Unimat SL backplate lever scroll chuck with a new backplate. A good accurate machine but limited by the spindle bore.
                                The Compact 5 was also used as the basis of the slant bed PC Turn 55 lathe. The Compact 8 to was used as the basis of one of the Denford range of CNC lathes, as was one of EMCO's CNC Mills.
                                Gray,
                                #388249
                                  Posted by Neil Wyatt on 30/12/2018 10:36:46:
                                  Picking up on Neil's point : This is worth a look **LINK**
                                  https://watchmaking.weebly.com/cowells-90cw.html
                                  Chris Trice
                                    @christrice43267
                                    The Cowells is also substantially smaller than a Compact 5 too despite being beautifully made.
                                    #388270
                                    Martin Hamilton 1
                                      @martinhamilton1
                                      I have noticed there are some very nice Emco Compact 5 lathes for sale @ various times on the Netherlands & German Ebay sites, they do tend to be more expensive than what we see in the UK for used machines. The thing i am not clear on though & perhaps someone can answer this is the Emco Compact 5 machines usable here in the UK that are sold over in Europe as they seem to be 220v motors & capacitors. Can these be used on UK 230v – 240v supply or will this cause problems. Thanks Martin.
                                      #388551
                                      Kiwi Bloke
                                        @kiwibloke62605
                                        The capacitors will probably be rated at 400V, so no problem. Individual households' UK mains voltage may be lower than you think – it depends on how far 'down the line' you are. However, even at full nominal voltage, the slight added heating would be most unlikely to be a significant problem.
                                        #388552
                                        Chris Trice
                                          @christrice43267
                                          Emco motors are known for running hot if used continuously so they're fairly resistant. If in doubt, let it cool off for a while before resuming.
                                          #388554
                                          John Haine
                                            @johnhaine32865
                                            I suspect that the only difference between machines made for the UK and the (much larger) European market would be the mains lead.
                                            #388567
                                            Martin Hamilton 1
                                              @martinhamilton1
                                              I just wondered why the European Emco has 220v on the spec plate on the motors & the UK models had 240v. I believe some of the later UK versions may have 230v on the plate.
                                              #388569
                                              Chris Trice
                                                @christrice43267
                                                I'm amazed it quotes 240V because the UK officially is 230V.
                                                #388572
                                                  Posted by Chris Trice on 31/12/2018 20:47:14:
                                                  … In a manner of speaking angel
                                                  https://www.nottingham.ac.uk/etc/guide-voltageoptimisation.php
                                                  Former Member
                                                    @formermember32069
                                                    #388579
                                                    Martin Hamilton 1
                                                      @martinhamilton1
                                                      Thanks for that Barrie, i know that some of the different voltage motors have 50HZ whilst others have 60HZ. Does that make any difference to running a different voltage.
