Earthing Issue on new machine
Home Forums Manual machine tools Earthing Issue on new machine
Viewing 3 posts - 26 through 28 (of 28 total)
  • #552928
    Buffer
      @buffer
      I have a consumer unit in the garage with rcd all done by an electrician and a pme earth system in the house. So many thanks for the reply.
      Brian Morehen
        @brianmorehen85290
        All sounds OK and safe to me .
        Good Look
        Bee.M
        #552936
        Emgee
          @emgee
          Buffer
          All I can add to your description is if the workshop is detached from the house and the earthing in your workshop is connected to the PME house system the conductor needs to be a minimum of 16mm.
          Sometimes with a detached workshop earthing is provided by an earth stake with a RCCB controlling all circuits, in this case any cpc/earth conductor (inc SWA) in the supply cable is insulated from the workshop system.
          It may be a good idea to get the earthing arrangement with the inverter and supply to the lathe checked by your electrician for peace of mind at least.
          Emgee
