Posted by Nimble on 28/05/2018 11:09:09:
Dave , I must admit I have limited electrical knowledge, but your first point is that the current needs to be measured, by using my suggestion the initial currrent can be worked out with a value thar will protect the coil. from damage. Then if there needs to be any variation necessary maybe your method is the way to go. As you can see I am in contact with a user and his auto electrician and I have already asked him about the resistance of the coil. Another factor that may have to be considered is the capacitor OK.
Neil.
I'm not on firm ground with tremblers at all, but ignition coils are better documented. Have a read of this analysis – yes indeed capacity matters too. At the end he reveals the primary of his example coil has a DC resistance of 1.7Ω and that the AC resistance at 100Hz is 5 times larger at 9.78Ω
An ignition coil isn't meant to be fed DC continuously; it's a pulse device and works in that mode unless something breaks. One problem with protecting coils based on measuring only their DC resistance is that you're liable to cripple their operating performance : a DC measurement causes you to fit a higher resistance than is actually needed, and you weaken the spark.
An ignition coil sparks once per pulse, so the frequency varies proportionally with engine speed between say 8 and 500Hz. Not so a trembler. If I understand correctly (always in doubt!), tremblers buzz the coil to send a stream of sparks to the engine. Spark streams seem to be useful in the slow moving large capacity engines fed low quality fuel used in early cars. (Model T Ford had a 3 Litre engine!)
In the case of a trembler, I think the frequency of the buzzer matters. Even if I'm right, the opertating frequency is another mystery – I'd guess 100 to 200Hz because it's mechanical, but…
In practice I suspect that Vintage will get his engine to run however he puts approximately 6V across his trembler terminals. It's just that some ways of doing it are cheaper/more reliable/easier/interesting than the others!
Edited By SillyOldDuffer on 28/05/2018 13:55:31
