drilling sandstone
drilling sandstone
Home › Forums › The Tea Room › drilling sandstone
  • #289869
    mick70
      @mick70
      need to make water feature for a viv i am building.
      planning on using sandstone but whats best way to drill it?
      assume a normal masonry bit no good?
      google just throws up drilling big bits, piece i will be using is only 1.5" thick and will then be siliconed to base piece which will have small drain hole in it to allow water to drain back into sump.
      #34878
      mick70
        @mick70
        #289871
        Martin Connelly
          @martinconnelly55370
          I would try a masonry bit. Why would you assume it is no good? You have not stated the diameter, that may have some bearing on the responses you get.
          Martin C
          #289872
            Decent masonary bit will be fine, sandstone is not that hard.
            #289876
            Jon Gibbs
              @jongibbs59756
              Depending upon the hardness, sandstone will drill easily with a good quality masonry bit with rotary only.
              For big holes I'd be tempted to try a TCT grit holesaw with a rod pilot after drilling a small through hole… **LINK**
              Jon
              #289879
              Richard S2
                @richards2
                Yep, Masonry Bits. Also agree with Jon Gibbs to pre drill small pilot hole first to avoid 'blowing out' on drill breaking through. Allows you to drill from both sides to finish hole cleanly. Diameter of hole would have been handy to know.
                #289900
                mick70
                  @mick70
                  sorry forgot to say planning decent hole in centre but wanting to chain drill various diameter smaller holes rd outside then remove center.
                  don't want it looking perfectly rd in middle.
                  Edited By naughtyboy on 21/03/2017 16:04:28
                  #289909
                  Gordon W
                    @gordonw
                    Depends on the stone– soft red best without hammer. Sandstone one of the easiest to drill. Don't be tempted to drill small holes unless you need them, bigger ones are easier, usually.
                    #289914
                    Bob Rodgerson
                      @bobrodgerson97362
                      If you are planning a decent sized centre holes then why not try a diamond coated hole saw. I drilled a 5" dia. through a reinforced concrete tank with one without any problems. I think if you try to chain drill you will break the sandstone before you get the round bit out.
                      #289917
                        @mike89748
                        My house is made of sandstone, and I have drilled lots of holes in the walls with an ordinary masonry drill. It works fine if the drill is kept sharp, and I do have a "green" wheel. A lot of masonry drills aren't very sharp even when new.
                        #289926
                        Raymond Anderson
                          @raymondanderson34407
                          A normal masonry bit will be fine. One thing about sandstone, [ probably won't apply to most on here ] It's far more abrasive to the drill bit than Granite , For example, a new Hilti bit [ for plugs and feathers ] 22mm Ø will put more holes in granite before it wears out than the equivalent bit in Sandstone. It takes longer to bore the Granite than the Sandstone, but the bit will do more holes, Due to the very abrasive nature of Sandstone. Soft compared to Granite, but very abrasive.
                          #289947
                          Frances IoM
                            @francesiom58905
                            if it’s anything like the sandstone Peel(IoM) + my flat is built upon just use a powerful water jet to make a very natural hole
                            #289956
                            Allan B
                              @allanb
                              Another voice for a good quality masonry bit, living in the middle of a big sand pit (central Cheshire) we have lots of the stuff around and as kids we use to build all sorts out if it, we never had any mortar but we could peg it together with hand drilled holes.
                              One thing I would say is to use a slower speed, as others have said no hammer action, and try not to use too much pressure, this will only fine any floors in the stone, and lastly clear the whole out regularly, this helps to stop the extra pressure pushing on the sides of the hole (I’m assuming you will be drilling down into the stone)
                              Allan
                              #289987
                              john carruthers
                                @johncarruthers46255
                                I had to drill a lot of holes in church masonry to take the window sadle bars. A masonry bit, sharpened, in a hand brace worked fine and didn't do too much damage to the fragile details.
                                #289994
                                Martin Kyte
                                  @martinkyte99762
                                  Copper tube and carborundum grit used as a hole saw with plenty of water lubricant. That's how you drill big holes in thick glass (like telescope mirrors) so you should find sandstone somewhat easier. Small nicks in the end of the tube helps retain the grinding material.
                                  regards Martin
                                  #290025
                                  Georgineer
                                    @georgineer
                                    Martin is thinking along the same lines as me. I haven't got a clear idea of the size of hole you are considering, but for moderately sized holes I would file some teeth in the end of a piece of iron pipe – gas pipe will do – and turn it in a drill. If you add water, the sand should make its own abrasive slurry.
                                    A star drill like this made out of un-hardened steel is surprisingly effective when used with a hammer, turning it slightly back and forth between blows and filing up the teeth when necessary. I once cut a number of holes in brickwork with a piece of old pushchair handle. The main drawback is the breakout as you reach the other side, as mentioned above.
                                    George
                                    #290163
                                    Ian S C
                                      @iansc
                                      I'v used tube as George described to drill holes in concrete Must have been about 40 at least, took a couple of days, it was for bolting airframe and wing jigs to the floor of our new hanger, and engine stands in the engine overhaul shop. the steel tube used was a bit of a broken tailwheel spring from a Cessna 185.
                                      Ian S C
                                      Cessna 185 B ZK-CFI
                                      #290309
                                      Ian S C
                                        @iansc
                                        For Neil , and others the finished item, rebuilt from a topdressing aircraft to above factory finish for Gore Aero Club, looks quite nice. Sorry the photos a bit fuzzy
                                        #290315
                                        Clive Hartland
                                          @clivehartland94829
                                          I put a central heating system into an old farm house circa 1640. the walls were 24" thick and I had to go through. I got a bit of steel scaffold tube and cut 'V's in the end and welded Stellite onto the tips, this was then used to hammer through the walls. Using 22mm copper pipe I was able to run a double run and be able to fix rads. across the two pipes. Customer was highly delighted with the result.
                                          I might add that i welded plough sgares with Stellite and they are still in use!
                                          #290371
                                          Georgineer
                                            @georgineer
                                            Posted by Clive Hartland on 24/03/2017 10:19:17:
                                            I put a central heating system into an old farm house circa 1640….
                                            You're older than you look then, Clive. It does explain why you can't remember the exact date, though.
                                            George
                                            #290374
                                              Posted by Georgineer on 24/03/2017 17:09:48:
                                              George
                                              He means he did the work about an hour ago George… smiley
                                              #290615
                                              Georgineer
                                                @georgineer
                                                Posted by SillyOldDuffer on 24/03/2017 17:48:07:
                                                George
                                                Ah. That explains it.
                                                G.
