Drill chucks
Drill chucks
Home Forums General Questions Drill chucks
Viewing 2 posts - 26 through 27 (of 27 total)
  • #144529
    Muzzer
      @muzzer
      Posted by jason udall on 20/02/2014 16:43:24:
      Just has a thought..on the subject of shank vs drill size…
      How do boring heads get on?..
      Or fly cutters..
      Hole saws
      Boring bars and fly cutters can't hold a candle to a solid piece of HSS or carbide – they are considerably less rigid. When a well maintained twist drill is working near its capacity, it's producing 2 continuous spirals of almost full width swarf. You'd only try to reproduce that rate of metal removal with a boring bar or fly cutter once even if it had the same cutting edge length. Hole saws have no means of swarf clearance, so you have to use a series of micro pecks to clear the swarf (dust!). Even during a peck, the rate of metal removal is pretty modest.
      The main reason I use a pilot hole is to ensure it starts centrally and to avoid the central core of the drill needing to cut. Although they are designed to drill without one, they need a greater force to advance the drill without a pilot.
      I have had issues with keyed chucks slipping but not with keyless (apart from cordless drills). That's presumably because the keyless chucks are inherently self-tightening.
      Ian S C
        @iansc
        Called into the local second hand shop today, a fresh few tools arrived over the last few days, one thing was a 3/4" Dormer drill, with a 3/4" shank, $NZ4, I might think about it, but I would have to take it down to 5/8" shank dia.
        Ian S C
