Dore Westbury Build
Dore Westbury Build
Home › Forums › Beginners questions › Dore Westbury Build
  • #85242
      @brian
      I am in the process of building a Mk1 Dore Westbury Milling Machine and need guidance. I have all the castings, materials, components and the detailed build instructions and drawings.
      The problem is this; I have arrived at the stage where I need to cut the rack in the Quill using only my ML7 Lathe. I have bored the bearing housing both ends of the Quill and had no problems at all machining all the other components for the machine, but cutting the rack as suggested in the manual is daunting.
      Solution; I would like to make contact with anyone who has been through the build process of a Mk1 and carried out this operation, who can guide me through, and past, the potential pitfalls.
      If this part of the build is not done correctly the work may grind to a halt, because replacement material is impossible to find.
      Any help and or comment would be very welcome.
      #5968
        @brian
        Help and Guidance needed
        #85251
        Andrew Moyes 1
          @andrewmoyes1
          I built my Mk1 about 30 years ago and don't remember any difficulty in following the instructions for cutting the rack. Have you got the instruction book that accompanied the set of parts? If not, I can send you the relevant bit.
          The method suggested is to clamp the quill to the vertical slide facing the chuck. The teeth are cut using a boring head with a long boring bar holding a home made cutter. As it is a rack, the teeth have straight sides so the cutter is easily made. The cunning bit is that the pitch of the teeth is the same as the Myford leadscrew so (assuming you're using a Myford) when you have cut one tooth, you just move the saddle along by one thread of the leadscrew and cut the next tooth.
          Andrew M
          #85261
          Tony Pratt 1
            @tonypratt1
            I too built my Mk1 about 30 odd years ago and cannot remember any dramas with the rack. I used a Myford vertical slide and I believe all went smoothly, use the shortest and biggest diameter boring bar you can and also use at least 2 clamping bolts to hold the quill in position. Go for the most rigid set up you can and take it slowly.
            Tony
            #85373
              @brian
              Andrew/Tony, thanks for the feedback, I have the build instructions and drawings of the rack profile.My main concern is first the grinding of the cutting tool and the depth of cut I should take at each pass. The guidance packing should be placed under the Quill, indicating a full depth cut. Brian
              #85374
                @brian
                I realy should read the text before I post, sorry.
                #85393
                Andrew Moyes 1
                  @andrewmoyes1
                  Brian – I remember now – when I machined the rack teeth in the quill, I could not think of a way to reliably depth the teeth to give the right amount of backlash with the pinion shaft. So I fitted an eccentric bush to allow the depth of mesh to be adjusted.
                  I bored out the hole for the pinion shaft (item 401) in the spindle head (item 312) from 7/8" to 1.1/8" and fitted a cast iron bush with the 7/8" hole bored off centre by 3/32". I was able to eliminate all but the tiniest amount of backlash and locked the bush permanently in that position with a grub screw. Well worth the extra trouble.
                  Andrew M
                  #85394
                  Andrew Moyes 1
                    @andrewmoyes1
                    Andrew M
                    #85401
                      @brian
                      Thanks Andrew,
                      when you cut the rack, did you follow the suggested method in the book mounting the Quill on a vertical slide? And how did you manage to grind the cutter, with a tool grinder or freehand. It needs to have an inclusive angle of 29 degrees with a tip width of 0.039 inches.
                      #85402
                      Sub Mandrel
                        @submandrel
                        Hi Brian,
                        You ask about grinding a tool to cut the rack – all you need to do is grind straight V-edges to the tool at the pressure angle for the gears, as a rack, being a section of a 'gear of infinite diameter' has straight flanks to the teeth.
                        Andrew Moyes 1
                          @andrewmoyes1
                          Brian – I ground the cutter by hand as I don't have a tool and cutter grinder. On an application like this, the odd degree or so of error can be tolerated. I ground each side in turn using the protractor head of a combination square set to the half angle and held against the shank of the cutter blank. The tip was measured with a micrometer and the end ground off until it was 39 thou as per drawing. Maybe not to the usual engineering tolerance but good enough and it worked perfectly. Go for it!
                          Andrew M
