Posted by Barrie Lever on 15/08/2019 21:49:38:
You really don't know what you are talking about regarding CE marking, as Robert has said the great majority of products are self certified.
The very clear difference between CE and UL/CSA is that the latter have to be submitted to the test house.
Check out the following and get back to me if I need to issue you an apology !!
https://cemarking.net/ce-self-certification/
https://www.conformance.co.uk/ce-marking-for-products/ce-marking-basic-information#what-can-i-do-myself
CE marking is not worth the small amount of ink used to print the label.
The system needs to be independently verified with a unique ID for each product, then it would have some value, like I say, where there is a will there is a way.
Barrie
Phew, thank god Barrie has pointed out I don't understand the CE system! Now there will be no real world consequences from the mistake. What a relief!
Unfortunately reading Barrie's links soon show it is Barrie who has the wrong end of the stick. True it is possible to self-certify quite a wide range of items at the moment. But self-certification applies to the cheap simple stuff with low safety issues, not the high-value items that make up British exports. (Non-EU manufacturers cannot self-certify; they can provide the documentation and markings, but it is the importer who is responsible.)
Presumably Barrie read the phrase;Generally, you can do everything yourself because the CE marking procedure is one of self-certification.' and stopped reading. The next sentence is: 'The only cases where it is not possible for the manufacturer/importer to do everything themselves are when the relevant directives specifically state that a Notified Body must be involved in the assessment of the products. These are organisations designated by national governments of the member states as being competent to make independent judgments about whether or not a product complies with the essential safety requirements laid down by the directives.' Broadly, this covers Medical Equipment, Radio Equipment, Pressure Equipment, ATEX (Explosive Atmospheres), Machinery, Work Equipment, and General Product Safety.
I'll try and make the point again: scrapping a system because no-one bothers to enforce minor transgressions (a local funding choice), is a bad idea when it screws over British exports of expensive items. Barrie is inflamed about Far Eastern import "bargains" that turn out to be duds, I'm worrying about British exports to Europe worth about £250,000,000,000 a year. That part of the CE system works. Anyone ever seen a European CE mark that was faked?
Just to finish off, self-certification is only legal when done in an EU member state. Self-certified CE Marks issued in the UK have no validity after Brexit until reasserted by the European importer. Be interesting to see how the Europeans respond to that detail; they might ignore or it, or they might apply the rules rigorously, inspecting containers at the border and turning back any containing non-compliant goods. You can't leave a club and expect to keep member privileges.
