Degree graduation strip
Home › Forums › Beginners questions › Degree graduation strip
  • #273308
    sean logie
      @seanlogie69385
      My topslide doesn't have any markings at all to tell me what angle the topslide is sitting at . I'd like to fit one to speed things up a bit . Can someone tell me the proper name so i can go looking for one .
      Thanks
      Sean
      #8454
      sean logie
        @seanlogie69385
        #273312
        Iain Downs
          @iaindowns78295
          I have an angle gauge which I got from lidl for a tenner or so. You can probably get them from ebay. The one I bought looks like this one on ebay, but was quite a bit cheaper.
          You can set the angle to 1/10th of a degree, which is certainly good enough for me. In fact there was a nasty piece of plastic on my cross slide which I was pleased to remove.
          #273319
          Bazyle
            @bazyle
            Protractor?
            #273320
            sean logie
              @seanlogie69385
              Interesting bit of kit …..
              http://www.zettlex.com/products/incoder/
              #273321
              John Haine
                @johnhaine32865
                Sean they are not normally "fitted" but engraved on the cross-slide surface with a fiduciary mark on the topslide base. Short of dismantling the lathe and getting one engraved, your best bet is probably to buy a suitable engineers protractor and use it to set the angle, probably relative to a test bar in the chuck.
                #273330
                Chris Evans 6
                  @chrisevans6
                  I made a new cross slide for my lathe, if you have a rotary table it is a simple job to engrave the degrees on the mill with a pointed tool.
                  #273341
                  wheeltapper
                    @wheeltapper
                    Hi
                    I posted this on another forum, it may help you.
                    cheers Roy.
                    Edited By wheeltapper on 22/12/2016 21:33:27
                    #273343
                    Chris Evans 6
                      @chrisevans6
                      Nothing beats a sine bar or accurate wedge to set the slide if you want real accuracy.
                      #273372
                      Russell Eberhardt
                        @russelleberhardt48058
                        Posted by Chris Evans 6 on 22/12/2016 21:24:27:
                        That does of course assume that the edge of the topslide is truly parallel to the dovetail slide. Worth checking.
                        Russell
                        #273453
                        Georgineer
                          @georgineer
                          From the title I thought this thread was going to be about people taking off their gowns, hoods and mortar boards.
                          George
                          #273466
                          Howard Lewis
                            @howardlewis46836
                            +1 for graduating the top slide, so that you never have to be concerned about this again.
                            May I suggest:
                            1) Remove the Top Slide.
                            2) Make a Fiduciary (datum) mark on the centreline of the spindle about which the Top Slide pivots.
                            3) Using a protractor (or whatever more accurate means you have available, such as digital angle gauge, sine bar, rotary table, dividing head, etc) scribe graduations on the Top Slide.
                            4) Reassemble, no longer have the problem, and have a Happy Christmas.
                            #273468
                            Anonymous
                              Posted by Georgineer on 23/12/2016 17:43:39:
                              Me too, although it's a long time since I've worn any of those items.
                              #273474
                              Bazyle
                                @bazyle
                                Seriously how often do you expect to set the topslide to 43 degrees, or 21 or etc. In practice you only require 3 or 4 actual settings. SO make a reference mark on the topslide and when you set it for screwcutting using a protractor or gauge of some sort make a corresponding mark. Any time you are doing a serious angle like for a Morse taper the graduations won't be accurate enough anyway.
                                edit – I wore my gown a couple of weeks ago at the company xmas dinner. It comes in handy for fancy dress in this case Super Hero member of the Cornish Pasty Eating Squad. (CPEQ is our department name so it sort of fits.) Mortar board hasn't been the same since the mice eat the tassel.
                                Edited By Bazyle on 23/12/2016 19:58:52
