Dead weight tester
Dead weight tester
Home Forums Workshop Tools and Tooling Dead weight tester
  • #270531
    Mike Lightfoot
      @mikelightfoot72419
      has anyone ever made or seen plans for a dead weight tester? Our club is looking at one in order to test our test gauges but they are a tad expensive, Cheers Mike
      #18305
      Mike Lightfoot
        @mikelightfoot72419
        Plans?
        #270542
        IanT
          @iant
          I'm pretty sure a design has been published Mike (most likely in ME) because I do recall seeing one, although it was a good while ago and I cannot find any reference to it I'm afraid.
          But maybe some else here can help?
          IanT
          #270547
          KWIL
            @kwil
            October 76 ME article by E W Sheppard
            Mike Lightfoot
              @mikelightfoot72419
              Ian, Kwil thanks for your swift response Kwil that looks like just the job Cheers Mike
              #270689
              Nigel Bennett
                @nigelbennett69913
                Whatever system is used to calibrate a Club's pressure gauge, it needs to be traceable to UK Measurement standards in order to comply with the S Fed/NAME 7/14"G regs. This would include the weights used on a deadweight tester and then having the deadweight tester approved as well. Having these calibrated at regular intervals would probably be as expensive as having a pressure gauge calibrated.
                Buying a calibrated pressure gauge isn't expensive – we got one from RS last year for £50.
                If a boiler goes bang and you can't prove traceability, the Insurance will become invalid.
                Hello, Mr McKay. Mr Barraclough…
                #270693
                Mike Lightfoot
                  @mikelightfoot72419
                  Nigel thanks will reinforce that info though our tester should be aware Cheers Mike
