De Walt grinder, linisher DW755
Home › Forums › Workshop Tools and Tooling › De Walt grinder, linisher DW755
Viewing 2 posts - 1 through 2 (of 2 total)
  • #93541
    Maurice Cox 1
      @mauricecox1
      I have just aquired an example of a De Walt DW755 linisher-grinder. The right hand end has a white grinding wheel with a water bath. At the other end is a belt linisher. When running, the front of the grinding wheel rotates upwards, the same as another water cooled grinder I have. However, this is also the case with the linisher belt, it moves upwards, tending to lift the work from the table. Is this correct? There is no means of reversing fitted.
      #16833
      Maurice Cox 1
        @mauricecox1
