I think if I were in this game I’d try one of two approaches.
If I had cobalt endmill, then that is the best and quickest way to reshape. And if CS says it works, he of the tangential tooling, praise be upon him, you can bet it does. I keep meaning to get a couple for roughing all my tool steel (but since I don’t use so much these days…)
Failing that, I would rough out with the 1mm cutting discs in an angle grinder – fast (very), waste little material and put little heat into what is being cut. And they don’t take the angle grinder under gyro forces. Then I’d grind with a proper tool and cutter grinder – or a grinding wheel if I didn’t have the other..
Edited By mgj on 29/11/2011 00:09:05
