Hi Jim,
A couple of notes about using powered sanders on metals. They will work very well on many metalwork jobs along with saws as others have mentioned. However-
1. If you have been using it for wood, and the dust collection areas of the machine have wood dust present, be very careful if you sand any ferrous metals that give off sparks – they can set the wood dust on fire. (Don't ask me how I found that out.)
2. Never sand aluminum. Finely divided aluminum particles can explode or catch fire. Same goes for aluminum on a grinder, except on a grinder there is also a risk of the wheel bursting if it gets loaded up with aluminum. Don't do it!
Good luck, have fun. One thing you will find invaluable for model engineering is a full set of fractional 1/16" to 1/2", number 1 to 60, and letter A to Z size twist drills if you work in Imperial measure. These are often sold as 115 pc sets. If you want to work in metric, a 0.5 to 6 mm dia by 0.1mm increments, and 6 to 13 mm by 0.5 mm increments will be a good start. Whichever system you buy, spend a bit and get a good quality high speed steel (HSS) set, preferably US or British made, but some Taiwanese ones are also fine.
FYI brass is an alloy of copper and zinc, bronze is an alloy of copper and tin. For small pot boilers to published designs you can use brass, but copper sheet is far better for boilers and bronze is preferred for fittings on boilers since it is more corrosion resistant. The zinc can leach out of brass especially in hot water and the extent of this problem varies with geographic regions. Once the zinc goes, the brass loses much of its' strength. Best to be safe and use bronze and copper for small boilers, and only use silver solder for boilers for the same reason. For silver solder supplies and techniques, look up CuP Alloys on the web. They also advertise in ME and Keith from CuP is on this forum periodically.
JD
