Cutting fins on an IC engine
Home › Forums › Beginners questions › Cutting fins on an IC engine
  • #293247
    Phil Catchesides
      @philcatchesides15448
      This relates to 'Matador' but is fairly general. The cylinders are steel and the plunge cut (about 0.15 inches deep by 0.09 wide) needed to form the fins is a bit of a struggle – lots of noise and juddering. I am using a narrow parting blade on a Super 7 at slow speed but it is complaining. Any hints or tips please people
      #8664
      Phil Catchesides
        #293255
          You could try a narrower 1/16" blade and then widen up the cut with your 3/32" one.
          #293259
          Nick_G
            @nick_g
            Have you got the tailstock supporting.?
            Nick
            #293261
            alan-lloyd
              @alan-lloyd
              This Is where a rear tool post is invaluable, I assume you don't have one? make sure the tool is on centre line or just under, not above and flood with coolant, the least over hang of the parting tool is better, you should aim for a ridged set up
              #293264
                Or just sort out why the lathe is chattering, maybe its just a Myford thing but at those sort of sizes I don't have a problem doing fins without a tailstock and with a standard front mounted parting tool and a bit of brushed on soluable oil.
                #293268
                Chris Evans 6
                  @chrisevans6
                  Do all the usual checks on the slideway gibs to ensure the chatter is not from movement. You say you are running at slow speed, maybe a little to slow so that you are scraping and not cutting ? By the way I have never used a Myford but folk do seem to do nice work on them.
                  #293278
                  JohnF
                    @johnf59703
                    Phil, you don't say what the OD is of the component ? I have a super 7 among other machines and it would take such an operation in its stride, no problem at all, no support needed and I never use or have a rear tool post.
                    Assuming an OD of something over 1inch I would suggest a speed of 350 to 400 rpm a correctly ground HSS parting tool and don't be frightened of feeding it into the work but don't allow it to dwell at the bottom of the cut—feed in and back of then repeat with plenty of cutting oil.
                    Works for me ! John
                    PS this is assuming your lathe is in good nick and adjusted correctly.
                    Edited By JohnF on 13/04/2017 20:55:11
                    #293294
                    David Standing 1
                      @davidstanding1
                      Does your parting off tool have enough side relief /taper ground into it?
                      #293343
                      Phil Catchesides
                        Thanks all for your thoughts. Have tightened up where necessary, checked and set the tool height, sharpened the tool, put on tailstock support etc but it is still noisy / juddery and wanting to dig in. I am running at about 200 rom on about 1.25 inches diameter. The tool is a proprietary cutting off tool and appears to have side clearance. I'm getting there with the fins but I am not a happy bunny 'cos it's not right
