Cut my first nice thread
Home Forums Beginners questions Cut my first nice thread
  • #8426
    sean logie
      @seanlogie69385
      #270526
      sean logie
        @seanlogie69385
        I tried aliminium for cutting my first thread but it was too gummy . So I thought I’d try stainless . Started of slow and easy and for the last two scratch passes I speeded up the lathe and it worked a treat . I took the chuck off tonight to check what tpi thread it was ,I’m a bit confused because there are two kind of half threads at either side of the full threads and I’m not sure which to count . The thread measured .50″ across and I counted 4 full threads . Am I right in saying the chuck thread is an 8tpi ?
        Sean
        #270537
        daveb
          @daveb17630
          Buy yourself a thread pitch gauge, combined Metric/Imperial, not expensive and takes away the guesswork. A set of Zeus tables is very useful, lot of info about threads, they last well too, I paid 50p for mine but it was over 40 years ago
          Dave.
          #270548
          Emgee
            @emgee
            Hi Sean, as suggested a pitch gauge would confirm the thread TPI but I would agree with you the 8TPI.
            Emgee
            #270575
            Hopper
              @hopper
              If you tell us what lathe you have, someone here will doubtless be able to quote you chapter and verse of the thread specs involved.
              #270577
              sean logie
                @seanlogie69385
                This is not a thread to size,this is pick a setting and run with it .
                Lathe is Fortis/clausing E/801 /B
                Sean
                #270828
                Ian S C
                  @iansc
                  Use your 6" steel rule, and if in 1/2" you count 4 threads, that would be 8 TPI.
                  Ian S C
                  #270832
                    Posted by Ian S C on 09/12/2016 13:40:42:
                    But do remember that when counting the crests, or the troughs, you are starting at zero
                    … It's a bit like counting 'fence panels'
