Posted by Bazyle on 28/05/2021 18:16:00:
…Another angle on this is an oil barell that you fill with water (mains provides a fair pressure) pushing the air out. …
By coincidence I've just read something similar. In 1717 Dr Halley built a diving bell and replenished the air by alternating lowering a pair of weighted casks to the divers, each time compressing fresh air in the barrel and releasing it inside the bell. 'I caused a couple of barrels of about 30 gallons each to be cased with lead, so as to sink empty, each of them having a bunghole in its lowest parts to let in the water, as the air in them condensed on their descent , and to let it out again…'
Anyway!
UK minimum water pressure is supposed to be 7 metres of head, about 10psi, so filling an oil drum would do the trick. Air pressure will be low until enough water enters the drum to compress it. I'd half fill the barrel before tapping off any air.
Is it dangerous? Maybe! There's a lot of energy stored in compressed air and releasing it with a bang can do a lot of damage, especially in a confined space. There are a lot of unknowns, always bad news in engineering:
- Water pressure varies and most properties get 1 bar (14psi) or more. Unless the pressure is measured (which can be done by estimating from the flow rate), how stressed a barrel will be is unknown. And unlike the diving bell example, the outside isn't supported by sea-water, only by the atmosphere. Not good.
- I've no idea how much internal pressure an oil drum will take before a seam fails, and because oil drums aren't designed or tested as pressure vessels this is high risk.
- As oil drums are made of relatively thin metal, they will inflate like a balloon putting severe stress on the seams, implying high risk of fatigue failure. How good, or bad the seams are at resisting alternating pressure is also unknown.
- The mode of failure is unknown too. Big difference between a seam that acts as a safety valve by opening up slowly, and a seam that ruptures all at once.
Some interesting guidance from this thread:
0.2 PSI – Breaks Windows
0.5-1.0 PSI – Shatters windows with body penetrating velocity.
1.0-2.0 PSI – Destroys typical wood frame structure
2.0-3.0 PSI – Blows in brick facing of steel frame building
5 PSI – Eardrum rupture
8 PSI – Fatal head injury (due to being propelled into stationary objects)
10 PSI – Serious lung damage
11-15 PSI – Fatal bodily injury (lung rupture or internal organ displacement)
Note: these are overpressures, i.e. the pulse of energy released in the instant that a pressure vessel fails. It depends on how much energy is stored (big boilers much more dangerous than small ones); how far away the pressure vessel is (stood next to is much more dangerous than 10 metres away), how confined (in the same room is much more dangerous than in the open air), and how quickly the rupture occurs (fast failures are far more dangerous than slow deflations.)
and, Ex : for vessel with 1 m^3 , diameter of 1m, under 10 bar, thk 5 mm, the energy is :
-compressed air : 2 300 000 J (The original thread gives formula.)
Note: 10bar is 145psi, 5mm thick steel is much stronger than an ordinary oil drum, and there are no weedy seams! 2300000J is the energy needed to deliver 0.63kW for an hour, or 1.7M ft-lbs. The example stores considerably more energy than an water filled oil-drum! Nonetheless, I wouldn't want to be anywhere near an oil-drum full of compressed air if it went pop.
Definitely approach with caution!
Edited By SillyOldDuffer on 29/05/2021 11:56:41
