collet chuck vs collet arbor used on lathe headstock spindle
Home › Forums › Beginners questions › collet chuck vs collet arbor used on lathe headstock spindle
  • #605748
    Y C Lui
      @yclui16187
      My Emco Compact 8 lathe is equipped with a ER25 collet chuck which can hold workpieces of diameter up to 16 mm. The spindle has a MT3 taper bore so it should be possible to put in a MT3 ER32 milling arbor to hold larger workpieces. I am wondering if this is a good idea because if this works Emco would not have made a collet chuck. Inquiring mind will appreciate some answers .
      #11266
      Y C Lui
        @yclui16187
        #605749
        Paul Lousick
          @paullousick59116
          The collet chuck will allow you to pass long pieces thru the spindle bore. A 3MT-ER32 will hold larger diameters but not pass anything thru the bore. Both have their advantages. An ER32 collet chuck is a better option
          Edited By Paul Lousick on 14/07/2022 09:21:48
          #605750
          Clive Brown 1
            @clivebrown1
            Presumably your collet chuck allows long pieces of bar to pass through the spindle.A chuck which is mounted on an MT would prevent this
            #605751
            Emgee
              @emgee
              Sounds OK for short work pieces, but check the MT3 socket will take a full length MT3 taper because many of the 5 series spindles need a reduction for a small length of the taper diameter at the small end.
              Emgee
              #605764
              bernard towers
                @bernardtowers37738
                Make your own spindle mounted collet chuck or buy an er25 flange mount collet chuck and make a backplate , also get oversize collets to 20 mm.
                #605769
                Paul Lousick
                  @paullousick59116
                  Bernard. The first line of the post states " My Emco Compact 8 lathe is equipped with a ER25 collet chuck"
                  Edited By Paul Lousick on 14/07/2022 11:21:27
                  #605781
                  bernard towers
                    @bernardtowers37738
                    SORRY MISREAD
                    #605791
                    DC31k
                      @dc31k
                      If you go for a MT3-mounted chuck, you will need a drawbar if you are to subject it to anything but axial compression loads.
                      #605810
                      old mart
                        @oldmart
                        You might be able to get a MT3 er40 collet chuck if larger size is important.
