Collet chuck
Collet chuck
Home › Forums › Workshop Tools and Tooling › Collet chuck
  • #340489
    Andy Freeman 1
      @andyfreeman1
      Hi,
      I need an ER40 collet chuck for my Myford Super 7.
      I have found two types, one with the collet chuck on an MT2 taper (quick and simple) and the other the collet chuck is on a back plate.
      This would then need mounting on a backplate with the 1 1/8" thread to screw onto the spindle nose. This set up works out more expenivse plus I would have mounting to do.
      Are there any pros and cons as to which one to choose ?
      Thanks
      #18842
      Andy Freeman 1
        @andyfreeman1
        Which type of collet chuck
        #340491
        MW
          @mw27036
          I have an MT4 spindle but I found that the morse taper collet chuck has concentricity problems either through manufacture or imperfect seating of the taper, maybe the drawbar isn't tight enough, In any case I found it couldn't give a satisfactory run out for what you would expect from a collet. Was hovering around 0.07-0.14mm runout 5mm or so from the chuck, checked against a silver steel bar for all that's worth, I can get better out of my 3 jaw.
          Michael W
          Edited By Michael-w on 08/02/2018 20:49:29
          #340496
          John Hinkley
            @johnhinkley26699
            Andy,
            As you rightly say, the morse taper version will be qick to mount and use. Its major downside is that you can't pass material through it like you can with the backplate-mounted type, so you're restricted to short lengths of material. An additional benefit to the latter is that once you've put the stock in the chuck, you can "bump" it to centre the workpiece by slackening the mounting bolts a little. If you only get one and can afford the extra cash, I'd advise you to get the backplate mounted one.
            Nick Hulme
              @nickhulme30114
              Go with the back plate variety, you machine the back plate in-situ to accept it giving good concentricity and you will then also have through capacity.
              #340505
              John Haine
                @johnhaine32865
                Backplate for definite! Slightly harder to fit and maybe more expensive but you can fit long material through and overhand is less.
                #340508
                David Standing 1
                  @davidstanding1
                  And regarding the MT version, if you can't use a drawbar with it, that's another negative mark against it.
                  #340510
                  Andy Freeman 1
                    @andyfreeman1
                    Well its looking like its going to be the back plate type from all these replies I have read.
                    Which then leads to one more question!
                    What would be the reason to get a 125mm diameter back plate type instead of the 100mm one? At the moment I can't think of a valid one but I am sure I will soon find out!
                    I appreciate your help
                    #340511
                    not done it yet
                      @notdoneityet
                      And if one option is chinese, beware that not all 2MTs are 2MT! One particular supplier is very risky, IMO. Even with a drawbar you may damage the spindle socket.
                      #340524
                      Jon Gibbs
                        @jongibbs59756
                        Have you considered making the body and buying the collet nut?
                        HH's excellent description here **LINK** would be easy to adapt. All ER collets use the same taper angle and the thread for the nut of ER40 is M50x1.5 and so a short piece of 2" or 2.25" bar stock would be all you need.
                        HTH
                        Jon
                        #340538
                        Chris Evans 6
                          @chrisevans6
                          Depending on if you have made/may make a ball turning attachment the 100mm is the way to go for better access.
                          My ball turning attachment is from the Steve Bedair style and the cross slide mounting of the attachment could foul on a bigger backplate.
                          #340542
                          John Haine
                            @johnhaine32865
                            Picking up Jon's suggestion I had a look at HH's page and it looks a good approach. When I have made ER collet sockets using the top slide to make the taper I've set the slide by chucking a bit of bar, turning to a precise mm size so it runs true, then sliding on a collet of the corresponding size. You can then use a finger type dti on the topslide on the side of the collet between the slits to set the taper. Worked fine for me. (Though now I just set the taper angle in a Mach 3 wizard.)
                            #340548
                            Baldric
                              @baldric
                              You can get an ER32 chuck that screws straight on to the nose if that is big enough for you and you don’t want to make one. I have one for my Boxford and use it when I can rather than a chick.
                              #340549
                              Douglas Johnston
                                @douglasjohnston98463
                                Posted by Baldric on 09/02/2018 09:06:07:
                                You can get an ER32 chuck that screws straight on to the nose if that is big enough for you and you don't want to make one. I have one for my Boxford and use it when I can rather than a chick.
                                Would that be an organic chick?
                                Doug
                                #340571
                                Vic
                                  @vic
                                  Does it have to be an ER40? There seem to be more fixtures and fittings that take ER32.
                                  #340575
                                  Nick Hulme
                                    @nickhulme30114
                                    Collets up to 30mm are available for ER40, that can be very handy and Stevenson's Collet Blocks are available in ER40
                                    #340584
                                    Andy Freeman 1
                                      @andyfreeman1
                                      Vic, the bar I am holdng is 25mm so I have to go up to ER40, which is a pity as I have a set of ER 32 collets
                                      #340596
                                      Baldric
                                        @baldric
                                        #340599
                                        Vic
                                          @vic
                                          Posted by Baldric on 09/02/2018 13:38:49:
                                          There is a 25mm collet for ER32, I haven't got one but have considered it.
                                          https://m.ebay.co.uk/itm/Gloster-ER32-collet-all-sizes-2-0-25-0mm-NEW-DIN6499B-Quality-collets-SALE-/370688002673?_mwBanner=1
                                          That’s interesting. Only trouble is I only have a 20mm bore on my lathe. Might come in handy for something though, I’ll have to remember it, thanks.
