Colchester Student Roundnose Stripdown
Home › Forums › Beginners questions › Colchester Student Roundnose Stripdown
  • #150997
    JOHN BRIDGE 1
      @johnbridge1
      I have recently bought a 1957 Roundnose in need of restoration, I have now bought another for parts to help with this restoration. The problem is that this second lathe is at the bottom of a fairly long garden in a shed with a narrow path leading to it. This Lathe is going to have to be dismanteled to get it out has anyone any tips for doing this in particular I would like to remove the main gearbox and also the saddle to reduce weight, any and all advice appreciated.
      JOHN BRIDGE 1
        @johnbridge1
        #151012
        Ian Parkin
          @ianparkin39383
          I dismantled mine to put it into a celler workshop 23 years ago
          I cant remember anything being particularly difficult to do
          It left the base cabinet as one with motor and switch gear installed
          bed ,headstock, gearbox saddle, tailstock and back panel as parts
          Ian
          #151015
          JOHN BRIDGE 1
            @johnbridge1
            Thanks Ian, I think the only thing I am unsure of is how the saddle comes off, is it just a matter of removing the 4 bolts that hold the apron on to the saddle and then sliding the saddle off the tailpost end. ( are these 4 bolts going down from the top of the saddle into the apron the only things that are attaching the 2 ) .
            Ian Parkin
              @ianparkin39383
              It was a long time ago 23 years now
              I'll have a look at my lathe as see if I can remember
              I think after removing the apron the saddle lifted off vertically
              Ian
              #151026
              JOHN BRIDGE 1
                @johnbridge1
                Thanks Ian I am most grateful.
                john kennedy 1
                  @johnkennedy1
                  John, if you are doing a big job like this you are going to need a manual. http://www.lathes.co.uk/colchester/
                  JOHN BRIDGE 1
                    @johnbridge1
                    Thanks John.
                    David Carpenter 4
                      @davidcarpenter4
                      If the path is smooth you can probably push it along. Or hire machine skids.
                      #151046
                      JOHN BRIDGE 1
                        @johnbridge1
                        I wish there are steps all the way down to the shed, one bonus though just had a phone call the machine is dismanteled heaviest part is the bed, going to collect shortly, takeing some muscle..
