Muzzer, don't take this as gospel but I'm guessing they are special to Harrison because I have seen two types that are very close together but still have the same number of splines.
Usually in a BS there will only be one standard with that number of splines.
Other reason is that they are very shallow splines, far shallower that any other BS straight sided splines I have had to do.
Having said that I do have a copy BS No 46 – part 2 – 1929 Six splines shallow but can't find a modern reference to it.
They go in nominal sizes measured across the tops of the teeth i.e. major diameter. What size is yours ?
I do have some change wheels here that I think are Colchesters I can double check these tables against one of those if i know what size I'm looking for.
(EDIT) Looking at the table there are 4 fits, two clearance fits, one transition and one interferance.
In all cases the OD is the same but the fit is made up by altering the minor diameter only slightly but the width if the spline is the critical measurement for the fit.
Edited By John Stevenson on 30/01/2014 09:59:10
