Posted by Ady1 on 11/03/2022 17:21:06:
You'll need to protect the exposed metal "instantly" with a film of oil or something, cast iron is very prone to flash rust
That is true, I used to clean up and deglaze cast iron brake drums in the kitchen sink with fairy liquid and wet and dry. There was an instant covering of light rust in the drums even when rinsed under the hot tap, and the insides of the stainless steel sink would have to be scoured with a brillo pad to remove the CI rusty dust. The rust inside the drums mostly came off simply by rubbing with a rag or tissue paper.
I would use the Solvol Autosol as recommended already on a polished CI surface, there is no water involved.
Steel wool will help, but is unlikely to result in a polished surface.
Edited By old mart on 11/03/2022 18:20:27
Edited By old mart on 11/03/2022 18:21:53
