Out of interest, I have been experimenting with Rubber blocks for the 37, central suspension as the specified springs do seem to be rather soft. I have experience of building David Hudson centre-less bogies, which use rubber components, and the suspensions is remarkable.
As the Hudson rubbers are too big for the Class 37 structure, I have been conducting some preliminary tests using rubber spacers on with an unfinished loco. It has been possible to establish rubber suspension systems that range from "harder than the Hudson rubbers" to softer than them.
The source of the rubber components is http://www.hawkeng.co.uk , I bought all three Shore Hardness grades available so that I could test everything out. I used the spacer kits with a 4mm hole, The kit allows for a length of suspension upto and beyond the specified spring length of 1". The actual length for any specific loco will depend upon the length of central bolt and the harshness/softness preferred for that loco.
These rubber components are much cheaper than conventional springs, and I suspect, just as serviceable, when battle tested.
