Clarke CL500M power feed
Home Forums General Questions Clarke CL500M power feed
  • #389509
    Simon Tyler
      @simontyler66546
      Hi
      I've searched and not found anyone that has not converted a Clarke CL500M to have powerfeed in X for milling.
      *Before everyone dives in and tells me to get a different lathe, that does not help my issue. I have the lathe and it's done me well.
      The lathe has power feed in X when using the lathe option, but not when using the milling option. Normally this is not an issue dong the jobs I do. But I've been slitting slots in shafts and have 800 to do and wanted to add power feed so I can debur whilst slitting. A powerfeed would save me about 3days of work so if I spend a day adding it then it's worth doing and having for future use.
      I've seen various power feeds on ebay for approx £200, but they obviously don't have the same setup as the Clarke lathe and wondered if anyone has converted to suit.
      https://www.ebay.co.uk/itm/X-Axis-Power-Feed-Kit-for-BRIDGEPORT-Milling-Machine-240-volt-model/371969858074?hash=item569b219a1a:g:EIUAAOSwBahVdck3:rk:1f:0
      This sort of device can be bought quite cheap and I was wondering if I could make a simple conversion plate to mount it on and maybe turn up a bush to convert the 12mm diameter shaft the CL500 has to suit.
      Anyone been there with this.
      Si
      Simon Tyler
        @simontyler66546
        Has anyone converted this?
        #389511
        Simon Tyler
          @simontyler66546
          I have put some pics of the the lathe here…
          John Rudd
            @johnrudd16576
            While my conversion doesnt cover your particular machine, I bought a similar power feed for my Chester 626 mill.
            On opening the box and examining how it all went together, it was obvious it was better suited to a Bridgie….that aside, I managed to get it to fit the mill X field. Had to make a couple of bespoke bushes and bore out the brass gear by a miniscule amount…
            Was it worth it? Absolutely… Go for it saves a lot if effort….
