Hi Dave,
You may get a bit of help from Little Machine Shop's trouble-shooting guide here:
< http://littlemachineshop.com/Reference/DriveTroubleshooting.pdf >.
If you haven't come across them before, LMS is the main US source of spares and
info for lathes which (like yours) originate from the Seig factory in China.
Andy
PS: I had difficulty reading your initial post, because a banner advert down the RH side of
my screen obscured much of it, which is why there are a lot of carriage returns and hence
wide line spacing in this reply, and in the copy of the post which I've pasted in below.
I found the excellent post created a while back on the forum a couple of years ago
http://www.model-engineer.co.uk/forums/postings.asp?th=38809&p=1
This board is the CL250 version ther actual pcb markings 'Xin Yun Electront SMD-FC250.
What happens is when the speed pot is advanced it goes from a standing to almost full
speed, from about 10 o'clock position, the speed is controllable slightly from this point!
It works perfect on a Lamp load varying very steadily but not the motor…. yet the motor
runs comfortably on a 12V DC bench top power supply.
As mentioned in the post I did some checks these are checking the post these are
measuring the pot and checking the voltage between pins 2 & 3 varys between 0 & 12V.
I've recapped using 105 deg. low ESR types.
If it comes to replacing the SMDs I can do that being in the trade… this fault is bugging
me, thinking it's around the feedback circuitry… be interesting to see what happens on
a 'dummy load' drawing an amp or two, which I've never tried yet.
The motor kicks better than the Co-op donkey when starting from a stop to full speed!
This board used the open type trimmers not the multi-turn trim pots.
Clues anyone pleas? Thanks
Unfortunately, I can't really read your post because a banner advert obscures the RH side of it
