Clarke cl 500
Clarke cl 500
  • #39527
    John Davies 13
      @johndavies13
      Lathe
      John Davies 13
        @johndavies13
        Hi guys does anyone know where I can buy a new or used 3/4 hp single phase 4 pole electric motor for my clarke cl500 metalworker lathe from.tried machine mart but they are coming back with over £400 which I thought pricey any help appreciated john.
        #450714
        Mark P.
          @markp
          John, have a look on ebay, loads there and I think
          that Machine Mart sell motors cheaper than £400.
          Mark P.
          #450731
          John Davies 13
            @johndavies13
            M mart £377 plus vat.none on ebay to suit .ie 16mm shaft.
            #450732
            martin perman 1
              @martinperman1
              John,
              For less than £400 Transwave will supply you with a 3/4 hp 3ph motor, remote control and VFD.
              Martin P
              #450733
              Martin Connelly
                @martinconnelly55370
                Search ebay for 16mm shaft motors and see if one suits. Note a 3 phase motor and VFD is well below £400 so don't dismiss this as an option.
                Martin C
                #450734
                nigel jones 5
                  @nigeljones5
                  For less than £100 delivered you can get this – just bore the pulley and file the keyway and its done **LINK**
                  #450735
                  Martin Connelly
                    I have just seen the other thread regarding this lathe. I wonder if you have bought a machine that has had a three phase motor fitted already. The standard stop start wiring would be disconnected if this was the case. Single phase motors tend to be defined by rpm and 3 phase by poles.
                    Martin C
                    #450737
                    martin perman 1
                      @martinperman1
                      I now have a question, I was told by MM that the shaft was 15 mm can somebody confirm that it is 16 mm, my new 3ph motor is 14 and I have to make a sleeve.
                      Martin P
                      #450740
                      Bill Dawes
                        @billdawes
                        Hi John, I used to have a clarke lathe/mill, I changed the motor for a 3 phase to use with an inverter, as far as I know still have the old motor which you are welcome to have, will have a look tomorrow and let you know.
                        Bill D.
                        #450741
                        Bill Dawes
                          @billdawes
                          I should add that working in the industrial fan industry we use a huge amount of motors, mainly 3 phase, but 400 quid for such a small motor is scandalous.
                          Bill D.
                          #450834
                          old mart
                            @oldmart
                            You can buy motors with a 19mm shaft for a fraction of the price, can the pulley bore be enlarged?
                            #450835
                              Machine mart sell this one for £96 if you can find a way to get the pulley bored out (assuming it meets the duty cycle requirement).
                              Size 0.75 HP
                              No. of Poles 4
                              Shaft Speed 1500 rpm
                              Frame Size 80
                              Shaft Dia. 19 mm
                              Starter Required Amps 4-6.3
                              #450841
                              Steviegtr
                                @steviegtr
                                I have this if you are interested. I took it off my myford to fit a 3 ph motor, it's in perfect condition & is wired up with a reversing switch & stop start station, 3/4hp 240v ac. All ready to go. Only needs a plug fitting. Can be seen working. I'm in Leeds so pick up only. £130 would snap my arm off.
                                Steve.single ph motor
