Has ther 430 a handle on the leadscrew?
If it has, you can measure the pitch. Give the handle a couple of turns, with the half nuts engaged, to take out any backlash.
Set a DTI against the Saddle,
Rotate the handle, in the same direct, for one or more complete turns.
The DTI reading, divided by the number of turns should tell you the pitch of the Leadscrew.
Say 1 turn moves the Saddle 0.125" Leadscrew pitch = 8 tpi, or if Metric, 3 mm
If you are lucky, you will have a DTI which uses the same units as the pitch of the Leadscrew. If not then you will need to use a calculator to convert from Imperial to Metric, or vice versa.
If you have any doubts, repeat the exercise, but do ensure that the movement is always in the same direction, to avoid any discrepancies caused by backlash.
HTH
