chuck grinder
chuck grinder
Home › Forums › Workshop Tools and Tooling › chuck grinder
  • #383194
    celso ari schlichting
      @celsoarischlichting85092
      I made this adaptation:
      greetings from Brazil
      Celso Ari
      #19151
        #383217
        Brian Wood
          @brianwood45127
          Hello Celso,
          Just out of interest, what was the thread at the back of the chuck machined to before you tapped it out 14 mm?
          #383224
          clogs
            @clogs
            Celso,
            I like ur idea BUT unless it's the vari speed model it's just to fast for anything bigger than 5mm…….the vari speed is used by a few stonemasons I know…..not much need woith steel…….
            in steel or ally bit to dangerous…..
            clogs…………be careful out there……
            #383255
            peak4
              @peak4
              It was only when I saw you using a drill bit at the end of the video that I realised the purpose.
              From the thread title, I thought you were going to use a mounted stone point and use it for grinding the inside of some lathe chuck jaws, using it as a toolpost grinder.
              I've done that with the motor off a Bosch POF 500a router, fixed in the toolpost on my Myford.
              A cheal old router, but with a removable motor unit on a standard 43mm collar.
              Bill
              #383275
              Ian Skeldon 2
                @ianskeldon2
                Why? Sorry but I just don't see the need to spend so much time re-inventing a drill, what am I missing?
                #383288
                Mike Poole
                  @mikepoole82104
                  Useful for drilling joists where you have to get in a space too narrow for a normal drill.
                  #383296
                  Ian S C
                    @iansc
                    Drill chucks are available for most brands of angle grinder. One of the main uses I'v managed to find is drilling holes in logs to inoculate the log with mushrooms, as used in that form of mushroom farming.
                    Ian S C
                    #383297
                    Ian Skeldon 2
                      @ianskeldon2
                      Ahh ok I haven't drilled joists so not come across that requirement and I suppose being able to remove the chuck easily will be useful should the grinder function be needed.
                      #383413
                        Posted by Brian Wood on 01/12/2018 15:51:02:
                        Hello Celso,
                        1/2 20tpi
                        #383416
                          Posted by Ian S C on 02/12/2018 09:29:36:
                          Ian S C
                          Here in Brazil does not exist to buy, we have to build it
