i did wonder if I should post this in the 'beginners' section but here goes……
I have a Chinese mini mill/drill which I purchased many years ago and the manual is long lost, so I'm afraid I can't quote exact model names or numbers. After a long period languishing in a shed at the bottom of the garden, it has been relocated in my new workshop and I've stripped it down for cleaning.
My question is what, if anything, should the leads screws (is that the right term?) be lubricated with prior to reassembly – oil or grease? I would assume that the screws are steel and they run in nuts that appear to be of brass, bronze or similar metal. The small amount of crud that was visible on disassembly didn't give me much of a clue.
Thanks
