Chester Chraftsman Lathe
Home › Forums › General Questions › Chester Chraftsman Lathe
  • #167503
    Robert Hamilton 5
      @roberthamilton5
      Hi!. out there. I have a Chraftsman Lathe from Chester. I have recently moved home and workshop. I have managed to pull the wires out of the start switch that live under a plastic at the bottom right if the gearbox. In side I have two plastic connection blocks. Each one has three terminals Numbered ! at the bottom. 2 at the top. 3 in the middle. I also have 4 wires Red N0.9. White No.11. Black N0.5. Brown N0.13 plus an earth that I know to do with. Can any one who my have the same Lathe please inform me with the info as to how to connect my wires.
      Many thanks.
      Regards. R.hamilton.
      #23548
      Robert Hamilton 5
        @roberthamilton5
        I have a wiring problem
        #167508
        Martin Peck
          @martinpeck15887
          Hi there
          The wires are as follows:-
          1 top left RED numbered 9
          2 left middle White numbered 11
          3 Bottom left Red and links to Top right
          4 Top right Red and links to Bottom left
          5 Right middle Brown numbered 13
          6 Bottom right Black numbered 5
          Hope this helps
          #167517
          Robert Hamilton 5
            @roberthamilton5
            Hi!. Martin. Many Many thanks. I will set it up in the morning.
            Regards. Bo b.
            #167537
            Bazyle
              @bazyle
              Find the manual online for the grizzly 9249 which is the same machne as the Craftsman and Warco BH600. The wiring pictures are even in colour.
              #167553
              Robert Hamilton 5
                @roberthamilton5
                Hi!. Out there Gents. Martin Peck Within an hour with the answer to my problem. Also Bazyle this morning with the wiring Pictures I might be able to understand.
                Thank you gents for your help and so quickly.
                Very kind Regards.,Bob.
