Thanks for replies.
DiogenesII: ".50 minutes an hour have slipped by.."
I think you may have anticipated my next question! When I first made one of these things I wondered what would happen if I somehow generated 'ticks' on a clock hand from, say, the secondary pendulum. Backward or forward ticks according to the sense of rotation. I reckon that 'on average' the hand would go in one direction albeit erratically.That's based on a perhaps half-baked notion of 'handedness' . If the pendulum is started in a clockwise direction say, then the the total angular momentum (call it positive) will diminish because of friction but can never become negative.
Ady1: Thanks for the links. Interesting. Those globes look beautiful.
Posted by John Haine on 09/09/2023 16:06:26:
Duncan, you're quite right, it's Minimag. The SPC1 or SPC3 (or is that no longer made?).
The SPC1 has a cored coil which makes it unsuitable for clocks but the SPC3 is un-cored. But for this application cored might be fine. Adjustment would probably be either changing drive voltage (1.5 – 4.5Vdc) or just proximity to magnet.
Robin that's cool – how did you make the bearings please? I'm quite tempted.
Thanks for the info about electromagnetic pulsing (and to Duncan as well). I shall experiment.
The bearings are bog-standard deep groove double shielded. Probably NSK, nothing special. I did make a prototype using ceramic ball bearings but the small improvement in running time wasn't worth the cost.
Robin.
Edited By Robin Graham on 09/09/2023 22:42:59
Edited By Robin Graham on 09/09/2023 22:58:02
