Centec 2b belts and mk3 quill DRO
Home › Forums › Manual machine tools › Centec 2b belts and mk3 quill DRO
  • #14186
    jason evans
      @jasonevans10206
      #530879
      jason evans
        @jasonevans10206
        Hi all
        looking to replace belts on my centec 2b (mk3 quill head), can anyone help with where to find a modern alternative. Also, has anyone fitted a vertical DRO to the mk3 quill head. Would be very handy to have one, but not sure how it could be fitted.
        thanks
        jay
        #530885
        not done it yet
          @notdoneityet
          What do you consider a ’modern alternative’? Are you expecting to change the pulleys? I just replaced mine with the same section V belt, bought from my local bearing company ABC.
          Mine has a single belt, even though the motor drive is by twin sheave pulleys.
          My quill (which had a dro read-out already fitted), has the reader fitted to the vertical head body and the scale screwed (by a suitable bracket to line things up) to the quill. It appears that it was nothing special and a straight-forward job, when fitted.
          Edited By not done it yet on 01/03/2021 07:01:45
          #530886
          Gary Wooding
            @garywooding25363
            The belts on mine are the same as NDIYs. I fitted a quill DRO as shown in the photo. Email me if you need more details.
            #530894
            jason evans
              @jasonevans10206
              Thanks guys. Don’t want to be changing pulleys, just want new belts. Any links to what and where I can find them.
              thanks for he DRO pic, exactly what I’m after. Any more details would be much appreciated
              atb
              jay
              #530929
              Dave Halford
                @davehalford22513
                The belts are 'A' section the length depends on the existence of a raising block or standard. The current size is written on the belt back. You can find belt length calculators on google that work from a steel rule measurement round the pullies.
                #530948
                jason evans
                  @jasonevans10206
                  Ok cheers will take a look. No riser block used.
                  atb
                  jay
                  #530957
                  noel shelley
                    @noelshelley55608
                    Once you know the section or have the old one take it to transmission specalist, EG Hayleys their a national company and I have always found them VERY helpful, and if you get the wrong one they will change it. Good Luck Noel.
                    #530960
                    Gary Wooding
                      @garywooding25363
                      Posted by jason evans on 01/03/2021 08:18:14:
                      **THIS** should link to a PDF describing my mods to a MK3 VH.
                      Let me know how you get on.
                      Edited By Gary Wooding on 01/03/2021 13:08:55
                      #530977
                      jason evans
                        @jasonevans10206
                        Thanks again guys. Will have a good read of that pdf Gary, many thanks.
                        #530980
                        not done it yet
                          @notdoneityet
                          My quill read-out looks almost identical likely exactly the same) to that on Gary’s machine. As I wrote earlier, I source my belts from ABC.
                          Without a location it is rather pointless giving specific details – unless it is an internet one. My local supplier provides a comprehensive service at very competitive prices, so I support them by using their outlet.
                          If I don’t know the belt number, I take along the belt and they match it. If I don’t have the belt I measure the pulley diameters and the centre distance – and then calculate the shortest belt length required. There is an adjuster on the Centec machine, so one size up usually suffices. A cam belt tensioner from a car will make a good replacement if yours is missing.
                          #531028
                          jason evans
                            @jasonevans10206
                            Just looked at belts. The two long ones are
                            Fenner A1600 A64
                            and the short one is
                            Balaco R567
                            im in Kent so will have a search around
                            atb
                            jay
