Posted by Chris Denton on 01/08/2014 18:14:55:
This arrived today and I've had a quick go with it. The CCGT are very good on aluminium, a very smooth polished finish.
Any advice for feeds and speeds on EN1A using CCMT?
My rule of thumb for ruffing is max depth of cut is 5 times the radius, and a feed rate of 1/2 the radius.
For finish cuts, I use 1/6 the radius for a fine finish, for general finish I use 1/4 radius as the feed rate, and depth of cut to being genrally 1/2 the tool radius.
Some lathes do not have the power or rigidity to run these ruffing numbers with anything bigger than an R0.2mm cutter.On my S7, I use R0.2mm TNMG tools, with 4340 or 4140, cut depth is 1mm on radius, 2mm diameter, but only a feed rate of 0.004 inches, about 0.1mm per rev. For finish passes , I use 0.2 to 0.4 mm on diameter. RPM wise, I think it is 690 rpm or so, the fastest on the slow pulley. As for a coolant, I use cooking oil.
