In the DailyTelegraph Motoring Supplement, Honest John recommended, driving for 20 – 30 miles to warm the engine and then driving at 5,000 rpm for several miles (Presumably Petrol, where a diesel would need to be at 4,000 rpm probably )
The engine needs to be running on as great a load as possible, to maximise exhaust temperature, to light off the catalyst and to burn off burn off excess carbon.. So high revs and high load, not low gears.
Clive, a third or fourth gear, full throttle blast up Wrotham Hill on M20, perhaps?
The Mazda 6 diesel used to upfuel, if the DPF did not regenerate automatically.
If still driven gently, the excess fuel could drain down into the sump.
I was told that the Instruction book stated if the the oil level reached an "X" mark, above MAX on the dipstick, the vehicle was to be taken immediately to a dealer for an oil change.
There were instances of engines running away on the diluted oil ingested from the closed circuit breather.
Often the damage is terminal for the engine, with pistons and injector tips melted!
If you have not witnessed a diesel engine running away, you have not missed anything. The acceleration is tremendous, and switching off has no effect. The engine is totally out of control.
I saw it on a test bed, (Deliberately ) and was able to disconnect the breather pipe. In a vehicle you can't. Declutching will overspeed and destroy the engine, and the brakes are going to struggle to contain things.
On the subject of Commer TS3; drivers used to Leylands or Gardners, which would lug down to idle speed, did not get on well with the TS3.
On Southdown, as a result of using cheap straight oil, on the Brighton to London express services, crankcase explosions forced a change to Shell Rotella.. Slogging the engine caused the wet liners to shift, allowing coolant into the sump. I saw engine changes at as little 35K miles, never more than 65K.
They were best kept above 1600 rpm. But being high geared, much over 2,000 was rarely available. Once I saw 2300 in fifth going down Peaspottage hill, on the A23. The speedo read 6:30 on the tiny watch that did duty as a clock, well past the final 70 mph graduation. The only thing to pass was a Lotus Cortina!
On TS3 powered tractor units the exhaust silencers were mounted across the front, beneath the bumper. On a Friday night, after a week around London, on the M1, there were often quite spectacular firework displays. On one occasion, I saw the tailpipe melting, with the final silencer red hot!
