Hi
forgive me as I'm a beginner.
I want to build a coal fired steam engine boiler of less than 5" in diameter. I've calculated the thickness of the walls to hold in the pressure. I'd prefer to use steel as I'm good at welding, but steel rusts and if its too thick the heat won't get across.
A lot of people suggest copper, but copper is astronomically expensive for a tube of suitable diameter and thickness to make a coal fired boiler.
What other materials would be suitable, can brass be used? I guess that would be cheaper?
What is the cheapest way of building a workable coal fired loco boiler that's long lasting and capable of holding pressure?
Also where is the best place for materials, I've tried Macc models but they don't give much of a description on the thickness of tubes etc.
thanks
Edited By Simon Robinson 4 on 19/11/2015 15:32:09
