Bronze /Brass
Bronze /Brass
Home Forums Materials Bronze /Brass
  • #29709
    Alan Gordon 4
      @alangordon4
      Alan Gordon 4
        @alangordon4
        Hi Folks. I am sure this has been asked before but is there a way of telling the difference between Brass rod and Bronze rod ? I have some rod but not sure whether Brass or Bronze ? The plan I am working with calls for a component to be machined from Bronze
        #297633
        nigel jones 5
          @nigeljones5
          there is a lengthy thread on here somewhere covering this – but it is difficult to tell. I can tell by the oxidation colour, brass looks brighter and cleaner than bronze.
          #297635
          John Haine
            @johnhaine32865
            I've got a nice bit of 1" bronze bar and its un-oxidised colour is much redder than brass – the latter being more "gold".
            #297644
            Alan Gordon 4
              @alangordon4
              Thank you gents, I wonder then is the wear properties different ? I guess they are but I have no idea. The problem I have is that the plan I am working from denotes a component to be made from Bronze but taking the above advice II now think I have a piece of Brass handy rather than buying a piece of Bronze.
              #297651
              Ian P
                @ianp
                Posted by Alan Gordon 4 on 11/05/2017 15:27:59:
                Why is it a problem if the plan (drawing?) calls for a part to be made of bronze?
                Its available from quite a few suppliers and although its more expensive than brass it does have different properties, one or more of which, might be relevant or important to the function of whatever you are making. Its unlikely a designer would specify bronze if brass would do.
                In industry one would have to comply with the drawing, obviously a bit different in a home workshop but it prudent to check with whoever you are making the part for.
                Ian P
                #297673
                Fowlers Fury
                  @fowlersfury
                  Depends what your stock "bronze" rod actually contains in the way of additional metals but assuming it's basic – just copper + tin then the quick way to differentiate is to clean both with fine emery and immerse them in some dilute mineral acid (preferably hydrochloric*). After a while the submerged brass rod will appear to have a copper colour due to the surface zinc being dissolved. However if your bronze rod contains aluminium or zinc it may not be so easy.
                  * Readily available from Fleabay.
                  #297686
                  Matt D
                    @mattd
                    Hacksaw a bit off and burn the chips with a gas torch? Then do the same with a bit of known bronze or brass and compare the colour of the flames? My school days are long gone but I seem to remember something in Chemistry lessons about this.
                    #297760
                    Robbo
                      @robbo
                      A previous thread here – **LINK**
                      #297764
                      Alan Gordon 4
                        @alangordon4
                        Thank you all for your advice and Robbe for the link.
                        Good information Ta
                        #297765
                          To answer the more important question, bronze is much better for bearings, but brass is OK for light duties.
                        Home Forums Materials Topics
