Graham's Blade tension meter is a much neater product than mine, but based on the one made and documented by Jacques.
The meter is clamped to the blade, before any tension is applied. Tension is increased until the DTI shows, FROM MEMORY, 0.05 to 0.07 mm extension.
Since using this technique, blades have lasted so much longer, and the cuts are more accurate.
I commend the device, and careful alignment to all readers.
