Hello John
First consideration is to use an austenitic stainless steel to prevent any corrosion of the joint in a damp or wet environment. These are the 300 series.
If you are not sure, use a magnet. Austenitic stainless is non-magnetic
Then use a flux suitable for capable of removing chromium oxide eg HT5
Nothing to choose between the silver solders other than meltng temperature. You pays your money and makes your choice.
regards
keith
PS If your stainless is magnetic you must use a silver solder that contains nickel to prevent that corrosion. Use 449 alloy but it is not as easy to use as say 455 or 438. Easier to use 300 series stainless – readily available from your usual source of tube.
