Boxford VM30
Boxford VM30
Home Forums Manual machine tools Boxford VM30
  • #97944
    David Hughes 3
      @davidhughes3
      Would anybody know the correct level/weight of grease in the 2 speed g/box of a VM30, not sure if the level that was in it was correct.
      David Hughes 3
        @davidhughes3
        #98753
        KWIL
          @kwil
          According to the Boxford original instructions the gearbox was filled with BP Energrease F600-EP at works and did not need further attention. When I cleaned and refilled my gearbox I used Castrol Semi Liquid Grease, Castrol Spherol – EPO Grease, as I recall around 20 fl. oz, enough to cover the gears at the base of the gearbox.
          #98843
          David Hughes 3
            @davidhughes3
            Thanks for the info,much appreciated, had found an alternative grease but was unsure of the level/weight, as like you I needed to replenish the grease.
