Dave Barr
As promised. Original gearbox lube was BP Energrease F600-EP, stated in Handbook as "should not require attention". From personal experience there is some leakage in use and storage. Available alternative is Castrol Spherol 00 EPO, refill is 280cc for a reasonably clear gearbox. Dip level from top of gearbox (remove taper plug upper left front top) appears to be 65mm down.
If you must look inside, tilt head to 45 degrees clockwise, remove side panel (long ones) and then remove gear box side panel screws, break sealing and remove metal panel. Clean and replace sealant (Hylomar Universal Blue Sealant) before reassembly.
