Boxford Size ?
Boxford Size ?
Home Forums Manual machine tools Boxford Size ?
  • #89242
    Boiler Bri
      @boilerbri
      I have a model A boxford lathe. I recently bought a fixed steady for it from fle bay. The steady was advertised as 4-1/2", so i thought i was OK.
      When i tried it it is about 1/2" too short!!! I have never measured my lathe centre height until now and find that it's sat at 5".
      The steady has not been modified, so what is the correct centre height??
      Cheers
      Bri
      #11922
      Boiler Bri
        @boilerbri
        #89243
        Ady1
          @ady1
          If you plug a centre into the headstock the lathe height is from the bed to the tip of the centre
          There were 2 types, 4.5 and 5 inch
          http://www.lathes.co.uk/boxford/index.html
          (though the actual centre height was 4 5/8&quot
          Edited By Ady1 on 17/04/2012 07:44:41
          #89244
          mgnbuk
            @mgnbuk
            IIRC the "normal" centre height for a Boxford was nominally 4 1/2" (I seem to recall the actual centre height was 1/16" or 1/8" over 4 1/2" ). but 5" versions were also made. You would appear to have the latter. Have you tried contacting Boxford with the serial number ? They are still trading, having moved recently to a new factory in Elland, about 6 miles or so from the original Boxtrees Mill site in Halifax.
            http://www.boxford.co.uk/boxford/
            #89245
            _Paul_
              @_paul_
              The later Boxfords were 5" centre height and as such require a 5" steady, looks like you may have acquired a steady for the earlier 4-1/2"
              Paul
              #89251
              Ian Hewson
                @ianhewson99641
                Hi
                Just a thought, would it be feasable to cut the mounting block in two, fit a spacer to each side and bolt together to extend the height?
                Ian
                #89256
                Boiler Bri
                  @boilerbri
                  Thank you for all your responses. It would appear that it is a 5" machine.
                  I am not into modifying things so if anyone wants a steady for a 4-1/2" machine PM me.
                  Bri
                  #89258
                  _Paul_
                    @_paul_
                    You shouldn't need to modify it.
                    If you have a mill or milling capabilities you could create a raising block for it as it's only a "V" way on one side, it dosent have to be "aerospace" accurate either as you have some room to manouver with the steady fingers.
                    Paul
